John, would you recommend using your rear hoop for recoveries? I don't doubt the strength of the hoop, but it was bought up by another member that it is simply held on by the thread of 4 bolts, I would not trust it at all. Maybe for towing but not for recoveries. Like I said I'm sure the hoop itself is up for recoveries my concern is that it's only held on by the thread of 4 bolts.
I have used it on my other 4x4 and this 4x4 plus made them for half a doz Comp trucks in Vic.
Never had a problem, Maybe talk to your local bolt bloke on how threads grab/forces etc to get peace of mind.
I do have backing plates in 6mm that after bolting on use the backing plate with Nyloc nuts .
Originally they were made to go each side of the roller fairlead on Land Rovers, Then I noticed that most if not all 4x4
had the 85 x45 bolt pattern on the rear. I've pulled cement trucks out of muddy drive ways , tojo S the lot.
I'm very confident in it as are some mining companies. Hope it answers some queries you have. I use the Hook BTW not loop
Edit::: Its actually the strongest one I make
I've found some GQs not a lot but some rust away at the front of chassis, where bog holes and bad cleaning has lead to the chassis failing.
Most GQ and GUs Ive looked at, that rear section is pretty well rust free, as no area for mud to sit and do its thang.
Just for different styles, I don't make hook one anymore Billy Bleed got last one.
I like the hook for ease of use, and you'll find things don't fall up. As hook has no retaining clip.
I like the loop as well cause its very very strong on its own and the M20 eye bolt one I call bush hoop.
Edit No I dont use backing plate on my GU or the other one ooops
I have to shout out a big thanks to Threedogs for his excellent service,sent a pm with a few questions regarding his recovery points that he makes all questions answered so I ordered,Cheers great service and the gear looks great too
regards neil
Reason: spelling
