15th May 2014, 02:51 PM
#321
The 747
lhurley
could it not be longer to fit a larger shackle?
Look at the picture, the hole is cut to match the hole behind it.
15th May 2014 02:51 PM
15th May 2014, 02:54 PM
#322
Winnie
Der... woops
1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me
15th May 2014, 04:14 PM
#323
John, don't most Bullbar mounting kits put a bolt through that tie down point?
Well, at least mine seems to.
Would these still fit?
The Following User Says Thank You to FNQGU For This Useful Post:
threedogs (15th May 2014)
15th May 2014, 04:35 PM
#324
The profile is the same as what is already there., would be ideal if as you say you could use the larger shackle
bit of work with the die grinder, two smaller shackles with a bridle sounds better
@ BenK not for all then hey
Might only be for the tricky motor/bar combo. Keep ideas coming
Looks like my quest for a one fits all wont happen, but at least I have all models covered
The Following 4 Users Say Thank You to threedogs For This Useful Post:
Alitis007 (15th May 2014), Avo (16th May 2014), Clunk (15th May 2014), growler2058 (15th May 2014)
22nd May 2014, 07:26 PM
#325
Administrator
Finally ordered some front recovery points off threedogs...
Happy to admit I have been running the gauntlet for too long!!!
22nd May 2014, 07:38 PM
#326
Hardcore
AB
Great stuff mate. Next time I'll pull you out of aeroplane with them. Nah probably good the yota came along not sure you could have stopped if I snatched you out from the front
Lucus30's 1999 GU ST TB45E
28th July 2014, 02:57 PM
#327
Just finished fitting a pair of Threedogs recovery hooks to my GU IV 4.2 tdi with a Nissan winch bar.
The Bull bar mounting bracket required some trimming with the angle grinder and the bolt hole through the tie down point needed a bit of reeming.
I used 50mm M12 high tensile (8.8) bolts 1.25 thread, got them from Repco, but Bunnings or any other hardware shop should have them. The original M12 (8.8) bolts are only 35mm long, not long enough. All up about 40 minutes for this old phart to fit. The two forward bolts screw into captive nuts, the bolt through the tie down hole (rear bottom) has a nut and big washers.
The Following 2 Users Say Thank You to TimE For This Useful Post:
Avo (28th July 2014), threedogs (28th July 2014)
28th July 2014, 03:29 PM
#328
good to see you got them fitted looks like I need to modify a touch by scalloping out a small bit.
Some they go straight on others need a bit of a grind, but good thing is they ain't going anywhere
28th July 2014, 03:32 PM
#329
Moderator
TimE
hey Time, do you reckon you could change the writing to White on that pic as i am colour blind and simply cant read it mate, its a blur.
Cheers bud
Check out my Toy -->
Rogue Dung Beetle
28th July 2014, 03:48 PM
#330
MudRunnerTD
Cheers bud
Yeah it is a bit blury, but click on the pic, then click on the magnifying glass at the bottom right of the pic, then clcik on "view original" magnifying glass that is also on the bottom right of the pop up pic, should now be readable. The text on the pic is basically the same as in the post. Hope that makes sense.
