Page 49 of 50 FirstFirst ... 3947484950 LastLast
Results 481 to 490 of 498
Thread: Outback Ideas Recovery points
  1. #481
    194 Post(s)
    I did this for a while in my GQ wagon, then ripped it out. I have a SS watertank behind the middle seats, plus a cargo barrier. What I found was the removal of the seats only gave me a height advantage of having the seats in place of about 125mm from memory. I had a flat ply floor on a 25mm rhs frame, and really found the area was not any more useful with the tank in the way. maybe you are looking to open the entire rear of the vehicle from back of front seats to rear doors? I hate to be the scare monger, but the old RTA will nail you for seat removal as well especially if the seat belts are left in place. The 'nightmare' VASS' engineer i consulted wanted to legally turn my 7 seater into a 2 seater because of hardware on the cargo barrier - ended up not using him and mine is now a registered 5 seater. Food for thought.
    175 Post(s)
    Quote Originally Posted by Rock Trol View Post
    Thanks Hodge but I am after a false floor/platform for the middle seats so I can turn it into a two seater. Something I can secure jerry cans, fridge, space cases etc.
    I am pretty sure TD has done it to his car.
    Sorry mate. I should have read your post properly.
    Hi mate plenty here just PM for a price
  5. #484
    @MudRunnerTD
    You will need the same ones as I have Darren. It isn't a direct bolt on like other points John makes. There is a metal lip on one of the bull bar's brakets in the way. However, John, threedogs' metal mastery resolved that fairly quickly. I met up with him several times while he took measurements etc... And then built them to suit, supplied together with special washers for load spreading purposes.
    I believe the set I have are the only ones of its kind he made. Yours might be the second!
    There is a tiny bit of grinding involved too. I have photos at home if need be.
    Sounds Awesome. I'm travelling back from the Flinders now and will be keen to sort this out. Can you pm me a price John and we will get it done mate. Eric can you link me your build thread cause I'm lazy. Lol.
    Thanks guys
  6. #485
    Do you think the same as Hodges would fit, check his biuld thread sorry its been so long but you know....... @MudRunnerTD
    Thanks John I thought I quoted you above but missed it. See above.
    Happy New Year gents
  7. #486
    Mar 2013
    NE Melbourne
    PM sent...........
  8. #487
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    @MudRunnerTD
    Hodge, looking at getting pair of recovery point from threedogs, been stumbling around the forum in an attempt to find your build thread (slowly finding my way, but a bit slow to get me head around it all). Could you give me a link of your build so I can have a look at what recovery points/fitting method you ended up with. Mine 08 GU IV wag with genuine steel bull bar / air bag compatible, Recovery hook bolts up to under side chassis rail(RHS). Thinking of the L shaped design (pic 1) or must say do like the look of the "T" profile build.
  9. #488
    .......... TPC's Avatar
    63 Post(s)
    Yours should be the same as mine.
  10. The Following User Says Thank You to TPC For This Useful Post:
    Bidja (27th March 2018)
  11. #489
    Jul 2017
    37 Post(s)
    [QUOTE=TPC;756197]Yours should be the same as mine./QUOTE]
    Thanks mate, is the same config as mine and will suit well. Cheers
  12. The Following User Says Thank You to Bidja For This Useful Post:
    threedogs (27th March 2018)
  13. #490
    Expert ozzyboy's Avatar
    Oct 2011
    springwood, qld
    been a while since a post here. are these still being made?
    cheers
    TB42E manual 1996 GQ 30 year anniversary
    33" maxxi bighorns, 3" EFS & Accessories
