26th June 2012, 12:41 PM
26th June 2012 12:41 PM
26th June 2012, 12:49 PM
The 747
Did you have the leak before you got the windscreen replaced?
26th June 2012, 01:14 PM
Yes. The carpet had been wet prior to the new windscreen being install. But never as wet as this. Though, there was a lot of rain in Esperance whilst I was there...
26th June 2012, 01:24 PM
26th June 2012, 05:47 PM
If it smells like coolant your heater core is cactus. If not, time to get the hose out and soak the windscreen and watch out for where it leaks.
OzzieNorm (26th June 2012)
26th June 2012, 10:27 PM
Coolant: heater core leak. Possible
27th June 2012, 09:02 AM
Smell the wet carpet. If it does smell like coolant you will know straight away whether its the heater core.
30th June 2012, 04:52 PM
wet floor
hi , check the valance under the wipers , they take this off to replace the windscreen , its held in place with plastic push plugs and fit into a small gromment that is sealed over time they perish and get holes which will cause it to leak into the passenger side of the car , it would be doing it more now as its been disturbed when the winscreen was replaced , hope this helps
30th June 2012, 06:17 PM
Enjoying the trips
I had this problem, did the hose test and water was fair flowing in the grommet in the fire wall where I had bought cables into the cab.
Take the glove box out (6screws) for a better look.
Filled it chockers with silocon makung sure it got around all the cables, job fixed. Dry as a chip!!!
1st July 2012, 12:02 PM
OzzieNorm
I had noticed coolant level dropping - during the 5400k the vehicle has travelled during the past fortnight
Yeah my coolant level drops too. But mysteriously disappears into thin air. No wet carpet, no dripping coolant in the engine bay and no water in the oil. But I can smell coolant when I get out of the car after driving it, but I have searched and searched and not found any leaks.
