Results 1 to 10 of 20
Thread: EPIRBs and PLBs
    Patrol Freak lorrieandjas's Avatar
    Brisbane
    EPIRBs and PLBs
    Hi All,
    Been a few threads lately about safety in the outback and tips and equipment necessary for emergency situations. Done a fair bit of in- and off-shore sailing and skippered a fair few regattas so had to learn a lot about EPIRBs (Emergency Position Indicating Radio Beacons) and PLBs (Personal Locating Beacons) so thought would drop some info on what they are, how they work, etc.
    EPIRBs are mandatory for boaties heading more than 2NM outside of calm or near-calm waters. They operate on the 406MHz digital frequency. Previously they operated on the 121.5Mhz frequency however this has been stopped and people who have older EPIRBs that operate on this frequency should buy a new one. The Australian Maritime Safety Authority monitors the 406MHz frequency as well as a network of non-geostationary satellites which operate similar to GPS to triangulate the signal and locate the beacon. Each beacon has its own unique identifier and you should register your EPIRB with AMSA as they can then correlate the owner with the particular device in question. In addition PLBs should also be registered with AMSA and registration is required to be updated for EPIRBs and PLBs every two years.
    Registration is free and can be done online at http://beacons.amsa.gov.au/registration.html
    If commercial or recreational pilots hear a signal on 121.5 or 406MHz they will also relay this to the authorities who will co-ordinate SAR operations which should have already been commenced on activation of the signal.
    PLBs differ slightly in they are smaller, do not conform to the same standards as required by EPIRBs (such as having to float with antenna clear of the water). PLBs must have a battery life of 24 hours, EPIRBs of 48 hours. In addition all EPIRBs and PLBs must conform with Australia/New Zealand Standard 4280.1.
    What's the difference between a PLB with and without a GPS? Basically the GPS makes locating the device more accurate. Without a GPS the accuracy is to about 5km. With a GPS the accuracy is improved to about 120m. That's a fair difference - and particularly on the sea where the difference in the accuracy could mean the difference between being found in time, or.......
    Now - all that said, an EPIRB/PLB is not a replacement for a HF radio or Sat Phone. These should be carried in my opinion and the EPIRB/PLB used as an absolute last resort - but that said if in doubt better to be safe than sorry. A lot of time if you ever are in an emergency and in touch with SAR they may tell you to activate your beacon to assist in locating you.
    EPIRB/PLBs should be used only once, and if I recall correctly replaced every three years. They also have a test feature built into them which should be used before every outing to ensure they are operating. They shouldn't be tossed in bins or left idle because if set off inadvertently a lot of resources are wasted which could have been saving someone else.
    Also - if you have one and don't know how to use it don't wait until you need to use it to read the manual or try and figure it out. They are pretty simple to use, but in a time of panic strange things happen!
    It's a long post already so won't go into minimum water rations, other emergency gear, etc. That can come in another post. Also, a lot of this information is already on the web but thought I would consolidate it and also add my own experiences of it. I have had to use an EPIRB on the water once - and it saved about 20 people. A decent PLB will cost you about $400 with a GPS.
    Sorry for the ramble but thought this might help someone out - and if anyone notices anything I've said in error shout it out and I will amend.
    Please note the definitive source of information on EPIRBs and PLBs can be found at:
    http://beacons.amsa.gov.au/index.html
    Jas
  2. The Following 13 Users Say Thank You to lorrieandjas For This Useful Post:
    AB (15th November 2012), BigRAWesty (11th April 2013), Bob (15th November 2012), boots (15th November 2012), Clunk (16th November 2012), Cuppa (15th February 2013), DX grunt (15th November 2012), jack (15th November 2012), Lux85 (9th April 2013), macca (15th November 2012), Maxhead (15th November 2012), NissanGQ4.2 (15th November 2012), Taffy241 (27th November 2012)
    If it saves one one life this post has done its job, more the one even better IMO
    lorrieandjas (16th November 2012)
  6. #3
    Patrol Guru 89gqpatrol4x4's Avatar
    Brassall
    nice thread lorrie, great info!
    GQ Snorkle Lockers front n rear
  7. The Following User Says Thank You to 89gqpatrol4x4 For This Useful Post:
  8. #4
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Great info mate, thanks for that
    ______ 2017 D-Max _______
  9. The Following User Says Thank You to Maxhead For This Useful Post:
  10. #5
    581 Post(s)
    Nice info mate, well done!
  11. The Following User Says Thank You to AB For This Useful Post:
  12. #6
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Great thread mate,
    I know they have free PLB's near my area for bushwalkers, I assume this service would apply to 4wd outings
    Just found this on the net, not sure if other states offer the free service.
    Epirbhire sell / hire EPIRBs, PLBs, Sat Phones etc http://www.epirbhire.com.au/
  13. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
  14. #7
    How's the serenity boots's Avatar
    Sep 2011
    The new PLB 's are registered to the rescue headquarters in Canberra . You have to provide your details and the serial number of the unit that you have . So they know who or what they are dealing with .Has to be renewed every couple of years just for conformation too .
  15. The Following User Says Thank You to boots For This Useful Post:
  16. #8
    Brisbane
    Quote Originally Posted by boots View Post
    Thanks boots - I'l update the top post with that info.
  17. #9
    Brisbane
    Hi threedogs - I hope so - I'd hate to think people still travel into remote areas of this country without a clue or proper planning - but as we all know it happens......
  18. #10
    This thread in combo with "death in outback" needs to be combined.
    Or at least a few tips on what to do and what to take' and when to use them .
    and not press your epirb as you have a splinter, this needs to be thought out the correct info put down that can be printed off in one page
    and ticked off like a check list. times to go. times to travel permits required, water, etc .if you cant tick all the boxes don't go.
    I'even have a mirror with the sighting hole in the middle off an aircraft, a simply survival list and things to take water purafication tabs the lot. as I said It'll take a few heads a few beers and a few nights to get this right, THERE CAN BE NO MISTAKES WHATS SO EVER, might even need p&wl or dnre and nat parks to come up with basics for different areas, this will be no small undertaking and only the best in their field contacted
