Gday,can anyone give me the cold valve clearance for a 4.2 tdi? Thanks.
From Bobs post taken from the manual...
According to the Manual that I have it is .35mm or .14Inch for both Inlet and Oultlet Tappets
Adjusting Intake and Exhaust Valve Clearance
Adjustment should be made while engine is warm but not
running.
1. Set No. 1 cylinder in top dead center on its compression stroke,
and adjust valve clearance 1 , 2 , 4 , 5 , 8 and 9 .
2. Set No. 6 cylinder at top dead center on its compression stroke,
and adjust valve clearance 3 , 6 , 7 , 10 , 11 and 12 .
Valve clearance:
Intake 1 , 3 , 5 , 7 , 9 and 11
0.30 - 0.40 mm (0.012 - 0.016 in)
Exhaust 2 ,4 , 6 , 8 , 10 and 12
Adjusting screw lock nuts:
: 15 - 20 N×m (1.5 - 2.0 kg-m, 11 - 14 ft-lb)
I Tighten lock nuts, by fixing the ad
Gday mate, firstly, i dont know the answer lol. But hopefully someone will be along soon to help you out. You may find it in the manual. Just get your post count up to 25 and you can download the manual. You could start a members ride thread or slip over to the introduction section and welcome a few new members and you'll have your post count up in no time
Hello from Under Down Under!
Oopps, there ya go wombat, AB was along to help in no time!
thats why he's the boss haha.
If you're following this Patrol, Stop... You're not gonna make it
Thanks for the replies fellas,was hoping that someone may have had a measurement with the engine stone cold,maybe I'm over thinking things,but I figure that by the time you switch engine off after getting to opperating temp,remove intercooler,rocker cover,and finally get to the last tappett to be adjusted,that the engine has cooled down a bit,so how accurate is it going to be,but if it can be done cold then all rockers are the same tempk?
Hey mate, I still set mine at .35 when cold and never had any troubles.
Thank for that mate,was told by someone else to set them at .008" cold,its always good to get a second oppinion !
