Results 11 to 20 of 29
Thread: 1999 2.8 gu with whie smoke and starting problems
    Apr 2011
    sydney
    ok manny thanks i will do the compression test tomorrow and hope its not that as a new head mm cant imagine how much that will be or even if its worth spending tat amount on it mmm
    It does have lift and front locker rock sliders winch ect but most of this can go on a new rig also
    Expert Thirsty's Avatar
    Oct 2011
    Raceview, Ipswich QLD
    Similar thing happened to TONKA'S Truck, His problem was the turbo. PM him and he will fill you in.
    Troy
    1998 GU TI LS1
  4. #13
    Apr 2011
    sydney
    hello again i have just done the compression test all 6 cylinders came up at 420psi??
    so doesnt look like a head prob? where to check next?? please help could it be the fuel pump?
  5. #14
    Apr 2011
    sydney
    hey thirsty tryed looking for tonka in the member list there are 4 ppl with this ady
  6. #15
    Could be the fuel pump there is an advance plate on the side which is cheap to replace (could be this) I think "the ferret" sells these. Sounds like your engine is in good nic. Try the advance plate and check your pump timing. To check the turbo pull both intake and exhaust off the turbo check there isnt excessive play in turbo shaft or any oil on the exhaust side of the turbo. If the turbo has failed you would get blue smoke as well and wouldnt effect it to much at start up as the turbo isnt doing anything at idle. Also when your driving there would be a lot of black smoke as well. Check your pump timing and replace advance plate see how you go.
  7. #16
    Apr 2011
    sydney
    ok do you have a number or email for the ferret at all as to get a advance plate and does he also reco the pumps?
  8. #17
    Check the vendors thread he is there. I dont think he does pumps but wouldnt hurt to ask. Also it wouldnt hurt to check your engine timing make sure everything lines up with the marks when your engine is on TDC
  9. #18
    Apr 2011
    sydney
    yer engine timing is good as had done the belt and water pump 4 months ago but ill take the cover off again
  10. #19
    Apr 2011
    sydney
    just treyed looking for vendors? no luck there
  11. #20
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Quote Originally Posted by kgibbo View Post
    just pm him mate he,s on here
