4th March 2022, 04:05 AM
GQ TD42 vac pump Alternator recommendations?
Got a silvertop GQ td42 with vac pump on alt in a GU4
my auto8 alternator doesn't give any voltage until 1300 rpm
my original Hitachi one died and it used to charge at idle once I excited it
and revved it a little bit to wake it up but it too struggled with lights on,
demister and ac on
I'm looking at replacement alternators to buy and alot of the reviews
are saying the same thing ( crap voltage at idle )
What is with all the crappy alternators that don't charge at idle
or can't hold 14v with the AC fans and lights on?
Can anyone recommend a alternator brand that will charge at idle
4th March 2022 04:05 AM
4th March 2022, 08:18 AM
Hey mate can confirm that mine is the same once she's had a good glow and the starters turned over lights on dash will just flicker . . Charges good once up and running but yeah not ideal. . Can you still get the Hitchi unit, other than that can't be much help sorry but keen also to find out. .
4th March 2022, 09:45 AM
the problem may not be the altenator . i have a zd myself ( vac pump separate from alt ) but have read discussions on the older models . it seems people upgrade the +ve power wire from alt to battery and the -ve from bat to engine to stop voltage loss . also there are a couple of wires that come plug into the alt . a solid white one and a white with red stripe . i think if i remember correctly the white with red stripe goes to instruments and the white goes to the power wire that goes from the alt to the battery but joins into the wire not far from the alt . both of these wires have had know common problems with breaks and dodge connections at the connector into the back of the alt . the connection and/or breaks need to be fixed in the white with red stripe wire . the solid white wire needs to be replaced and run all the way to the battery +ve terminal so that it will read the voltage properly so the alt will put out enough voltage . these wires don't need to be larger as one dosen't carry much load and the other is only a sensor wire .
10th March 2022, 02:54 AM
Going to try source a 66m alternator pulley like this one
https://store.alternatorparts.com/pa...ternators.aspx
just having a hard time finding someone to ship it to australia
also going to do diode trick to see if this will help aswell
29th March 2022, 11:20 AM
i had to go through this not so long ago,
i was in a rush for one i ended up buying a jaylec 80a with vac pump on the back from patrol apart.
Then i ran into the issue that it doesnt charge while idle witch is a pain when your in traffic and its raining, heater on, demister on ect the wiper motor is so slow haha
5th August 2022, 03:53 AM
Ordered a UFI Alternator kit comes with a bosch 160amp alternator and some bits and bobs for the bracket spacer plug, will keep updates when it arrives
The Following User Says Thank You to Bozanceroz For This Useful Post:
MudRunnerTD (5th August 2022)
5th August 2022, 12:00 PM
Moderator
Bozanceroz
160amps!!!! I want one of those!!! Have you got a link please
Check out my Toy -->
Rogue Dung Beetle
7th August 2022, 06:47 PM
MudRunnerTD
I've spoke to Matthew from UFI about it check ur PM
7th August 2022, 06:49 PM
Bozanceroz
going to be ordering a vacuum gauge tester tool and seeing how much vacuum i pull at idle and at 1000rpm and 2000-3000 rpm
then im going to be installing a hella up28 vacuum pump off a ve/vf commodore with a gq vacuum canister setup and test the vacuum again
ill be doing this after my trip hopefully
7th August 2022, 08:27 PM
