Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Rear LED Light fitted
    Perth WA
    Quote Originally Posted by moose maverick View Post
    Nice neat install do you have it plumbed into the reverse lights or just a switch on the dash? Give those pesky tailgaters a nasty suprise!
    I wired mine to come on via either front or rear switch or reverse lights if front lights are on.
    2004 GU ST 3.0 DDi 2" Tuff Dog Lift, Warn 9000lb, Custom dual Batteries Redarc, Safari Chip + Snorkel, 3" exhaust, NADS, MBC, DIY can, PWR Int,+9" fan, 7" GPS-DVD-TV Igo8 and Ozi with 2cams,6.5" Kicker splits and 6x9", Pillar+ Racetech EGT-PSI, Heated seats, fixed compressor, Arduino dual battery and engine/OAT temp display, 3" Projected 50W HID's with halo DRL's........so far.
    Jul 2012
    Im looking at doing this exact same thing. Found the brackets on ebay for over $100 but will make my own!
  4. #13
    Nice job, ditto with nakkers drill small hole and put a rubber grommet to suit. A lot of lumens for 15 watts
  5. #14
    Brisbane
    Hi all, In regard to the live switch in the dash, this can/will come round to bite you if a copper comes up behind you and you light him up. I think it's against the law or not exactly legal to have the swithch mounted close to driver. A tricky three way switch connected through the reverse light circuit will save a fine.
    Quote Originally Posted by knakkers View Post
    Separate switch in dashboard wired directly to battery. So I can switch on when ever I like. Yeah it's good for anybody that tailgates or hi-beams me from behind. Lol
  6. #15
    Expert Cbates's Avatar
    Lilydale
    Great fit mate, Britelight are great and really helpful! got a work light from there myself!
    did you just weld the bracket to the side of the spare wheel holder?
  7. #16
    Maryborough Qld
    "LED light (5x3w) 1050 lumen output"
    knakkers, mate you can never have enough light, great work
  8. #17
    Advanced knakkers's Avatar
    Hampton Park
    Cbates, on the GU Patrols, you have to get a extension bracket fitted between the door skin & the spare wheel bracket to fit 33's on, so that extension bracket has holes pre drilled in it. So bolted the pole onto the extension bracket
    Now Divorced I can do what i like when i like. How good is life now
    02 GU111 Patrol 3.0TD Man, Chipped, Redback 2.5" Exhaust, Safari Snorkel, OME 2'' Lift, ARB W/Bar, Tigerz11 12000Lb Winch & R/Rack, IPF Lights, Cooper S/T Maxx 33's, Dual battery system, Uniden UHF, ARB fridge/freezer on ARB Slider, & heaps more
  9. The Following User Says Thank You to knakkers For This Useful Post:
    Cbates (14th July 2012)
  10. #18
    Advanced roon's Avatar
    Jul 2012
    pakistan peshawar kpk
    very nice leed light
