14th June 2012, 11:07 PM
#11
moose maverick
Nice neat install do you have it plumbed into the reverse lights or just a switch on the dash? Give those pesky tailgaters a nasty suprise!
I wired mine to come on via either front or rear switch or reverse lights if front lights are on.
2004 GU ST 3.0 DDi 2" Tuff Dog Lift, Warn 9000lb, Custom dual Batteries Redarc, Safari Chip + Snorkel, 3" exhaust, NADS, MBC, DIY can, PWR Int,+9" fan, 7" GPS-DVD-TV Igo8 and Ozi with 2cams,6.5" Kicker splits and 6x9", Pillar+ Racetech EGT-PSI, Heated seats, fixed compressor, Arduino dual battery and engine/OAT temp display, 3" Projected 50W HID's with halo DRL's........so far.
14th June 2012 11:07 PM
10th July 2012, 01:46 PM
#12
Im looking at doing this exact same thing. Found the brackets on ebay for over $100 but will make my own!
10th July 2012, 01:56 PM
#13
Nice job, ditto with nakkers drill small hole and put a rubber grommet to suit. A lot of lumens for 15 watts
11th July 2012, 01:56 PM
#14
Hi all, In regard to the live switch in the dash, this can/will come round to bite you if a copper comes up behind you and you light him up. I think it's against the law or not exactly legal to have the swithch mounted close to driver. A tricky three way switch connected through the reverse light circuit will save a fine.
knakkers
Separate switch in dashboard wired directly to battery. So I can switch on when ever I like. Yeah it's good for anybody that tailgates or hi-beams me from behind. Lol
11th July 2012, 06:21 PM
#15
Great fit mate, Britelight are great and really helpful! got a work light from there myself!
did you just weld the bracket to the side of the spare wheel holder?
11th July 2012, 06:46 PM
#16
"LED light (5x3w) 1050 lumen output"
knakkers, mate you can never have enough light, great work
14th July 2012, 09:15 AM
#17
Cbates, on the GU Patrols, you have to get a extension bracket fitted between the door skin & the spare wheel bracket to fit 33's on, so that extension bracket has holes pre drilled in it. So bolted the pole onto the extension bracket
Now Divorced I can do what i like when i like. How good is life now
02 GU111 Patrol 3.0TD Man, Chipped, Redback 2.5" Exhaust, Safari Snorkel, OME 2'' Lift, ARB W/Bar, Tigerz11 12000Lb Winch & R/Rack, IPF Lights, Cooper S/T Maxx 33's, Dual battery system, Uniden UHF, ARB fridge/freezer on ARB Slider, & heaps more
The Following User Says Thank You to knakkers For This Useful Post:
23rd July 2012, 03:35 AM
#18
