4th June 2012, 08:38 AM
Injector crack pressure tester diy
I was thinking about making an injector crack pressure tester.
Heres my thoughts.
Clutch slave cylinder and a gauge similar to a compression tester attached wich you press to reset.
A small pot of some sort running through a filter for the fuel feed.
Just not sure if a clutch slave would compress diesel at a high enough pressure to crack the injector .
4th June 2012 08:38 AM
5th June 2012, 04:36 PM
5th June 2012, 05:44 PM
Cool i am sure i have an old bottle jack lying around somewhere.
5th June 2012, 10:31 PM
Are you looking at playing with your injectors?
5th June 2012, 10:54 PM
Yes have a spare set here to mess with.
5th June 2012, 11:03 PM
Make sure the area is absolutely spotless that you are working on them. In a shop these are all done in an air con "white room" Im not sure on the exact figures of a standard pump but may be worth a look in to see if she can supply enough pressure to crack them once you have bumped your crack pressure up. I would imagine it would be right just be worth a look in. If its more power you are chasing you standard injectors will supply quite a lot of fuel before needing upgrading its mostly the pump that cant keep up thats why plungers are modded to allow more fuel.
6th June 2012, 11:42 AM
Don't set them over 110bar.
About all you can do is look for a lazy injector (pop pressure) and the spray pattern.
My ute makes around the 190odd rwkw with standard injectors.
