Results 1 to 7 of 7
Thread: Injector crack pressure tester diy
    Patrol Freak
    I was thinking about making an injector crack pressure tester.
    Heres my thoughts.
    Clutch slave cylinder and a gauge similar to a compression tester attached wich you press to reset.
    A small pot of some sort running through a filter for the fuel feed.
    Just not sure if a clutch slave would compress diesel at a high enough pressure to crack the injector .
    Advanced
    Mildura
    Patrol Freak
    Cool i am sure i have an old bottle jack lying around somewhere.
    North brissy
    Are you looking at playing with your injectors?
  6. #5
    Patrol Freak
    Yes have a spare set here to mess with.
  7. #6
    North brissy
    Make sure the area is absolutely spotless that you are working on them. In a shop these are all done in an air con "white room" Im not sure on the exact figures of a standard pump but may be worth a look in to see if she can supply enough pressure to crack them once you have bumped your crack pressure up. I would imagine it would be right just be worth a look in. If its more power you are chasing you standard injectors will supply quite a lot of fuel before needing upgrading its mostly the pump that cant keep up thats why plungers are modded to allow more fuel.
  8. #7
    Advanced
    Mildura
    Don't set them over 110bar.
    About all you can do is look for a lazy injector (pop pressure) and the spray pattern.
    My ute makes around the 190odd rwkw with standard injectors.
