Page 1 of 2 12 LastLast
Results 1 to 10 of 20
Thread: What aftermarket turbo do you have on your TD42?
    Sep 2011
    And what sort of hp are you getting from it with what mods? I'm mainly curious to see figures on the TD05 and GT2860's but would be interested in seeing a broader range for comparisons sake. So if you have the info post away. Cheers.
    North brissy
    Modified td05 pumping 14psi unintercooled making 150 or so hp at the treads.
    gt2860rs, 10.5 psi, intercooled 95rwkw
    Sep 2011
    Considering the standard non turbo TD42 put out only 85kw at the flywheel those are some pretty good gains. Keep em coming guys. silverbar any reason why you don't wind the boost up a little more? especially being intercooled.
  6. #5
    It's a black top motor. And I'm looking for reliability over big power.
  7. #6
    North brissy
    mines a blacktop . And so is my GU TD42Ti
  8. #7
    Sep 2011
    Can you share what mods are done to the TD05 nissannewby? How much extra gain has the mods made? I know that united fuel in the west modify the td05's is it one of theirs?
  9. #8
    North brissy
    Nuh its not that modified it came with the dts kit and i have had it high flowed however there is another mod i have done which i think was far more beneficial than high flowing the turbo. Atleast at the boost figures im running.
  10. #9
    Patrol Freak
    It would be rather hard to compare results due to fueling some people drive along producing a trail diesel behind them wich of course will give you more power.
    I run a t3/t4 .63 rear .50 front oil only turbo no idea what power it is producing but it has more go then a stock gu turbo little smoke and low egt's.
    Have to dyno it one day just to get a ball park figure as that is all they really are they vary so much .
  11. #10
    North brissy
    Yeah real world comparing is where its at mine being unintercooled i can push the pyros past 500 if i keep my foot buried into it however i did line up against a mate of mines GQ which is w2a intercooled modded pump running 16psi with a dts kit and there was nothing in it. Stock GU's are terrible from the factory my GU use to be but have since wound some fuel into running 14-15 psi and its much bettter now
