15th October 2010, 09:41 AM
#11
Patrol Guru
YNOT
Even with one turbo it's still a nice engine - post '98 VQ30DET 210kw @6000rpm, 386Nm @3600rpm on 7 psi boost.
Tony
Yeah but from what I've heard they are an a$$hole engine to work on.
15th October 2010 09:41 AM
15th October 2010, 09:47 AM
#12
Timbo
Nar I've worked on a lot worse.............. Like all engines thay have there good & bod points but the biggest thing is dealing with the height & reach you need when working on a Patrol so when you get used to that its not to bad at all.
15th October 2010, 12:26 PM
#13
I've never worked on a VQ motor, but in a big engine bay like the Patrols have it should be a lot easier to work on than say a Skyline that had the engine bay built around the motor.
Tony
15th October 2010, 02:25 PM
#14
Patrol Guru
I thought the VQ's were in the 300zx's? Along with a maxima I think
15th October 2010, 07:20 PM
#15
300ZX's had the older cast iron block VG30. Later Maxima's did get the VQ30, earlies still had the VG30.
Tony
19th December 2010, 01:47 AM
#16
ar3nbe
Its apparently quite easy to turbo the RB30 in the GQ's by using parts out of a VL turbo. All the injections gear is pretty much a straight swap, as is the turbo gear. Gq block already has the oil and water lines in the block, good to go.
Im planning on doing a turbo conversion in the next six months or so.
Do you plan to post a blow-by-blow (pun intended) of the process here. I for one (and perhaps the only one) would be chuffed if you do.
Cheers,
Rick
19th December 2010, 08:56 AM
#17
He hasn't been on the forum since the middle of October so I doubt it.
Tony
19th December 2010, 10:09 AM
#18
Sure. I thought it might be worth a try. Just in case...
