Page 1 of 2 12 LastLast
Results 1 to 10 of 18
Thread: RB30 reconditioned to an RB30ET.....
    Oct 2010
    Brissi
    I have a 1990 GQ with an 3B30E (also runs on gas) and want to recondition and turbo it...
    What are your thoughts??
    Oct 2010
    Brissi
    Was just informed that there is no turbo kit available for the RB30 and the best thing to do is put a VL engine in and build it up from there.... answered my own question lol but for anyone who was interested...
    Legendary
    What part of Brisbane are you in?
    Reco the RB30 bottom end and put an RB25DET top end and turbo on it.
    Tony
    Advanced GQ4.2's Avatar
    Warrnambool, VIC
    or just put a rb26dett in it, stuff frigging around with old school RB30's
  6. #5
    Oct 2010
    Brissi
    Im from the northside, cheers fellas i'll look into.
  7. #6
    Advanced Mav's Avatar
    Sep 2010
    I have the RB30et in mine, i like it, but i'm going to go a VQ30dett
    This is quite an easy and cheapish conversion, and the specs of the stock VQ are only JUST lower than a LS1, but are a LOT better than an RB30et
    Mind you a well sorted RB30et has enough power to keep up with most 4WD's
  8. #7
    Legendary
    VQ30DETT-nice! How hard is it to adapt this to the Patrol driveline?
    Will it be a custom twin turbo set up, VQ30DETT was only used in Nissan race cars?
    Tony
  9. #8
    Sep 2010
    Quote Originally Posted by YNOT View Post
    Tony
    It is pretty easy as far as i've been told, all Nissan not a single bulldust adapter in sight
    And there is 1 too may T's in there it should be VQ30det, but you never do know what's around the corner
  10. #9
    Legendary
    Even with one turbo it's still a nice engine - post '98 VQ30DET 210kw @6000rpm, 386Nm @3600rpm on 7 psi boost.
    Tony
  11. #10
    Oct 2010
    Its apparently quite easy to turbo the RB30 in the GQ's by using parts out of a VL turbo. All the injections gear is pretty much a straight swap, as is the turbo gear. Gq block already has the oil and water lines in the block, good to go.
    Im planning on doing a turbo conversion in the next six months or so.
