21st May 2012, 12:40 PM
ordered wrong size, should i return?
Hi guys ive just ordered 4 new sunnys, and when they arrived they sent 15s instead of 16s like i ordered, now should i return them and get the 16s or better to keep the 15s now? its a 1999 GU
21st May 2012 12:40 PM
21st May 2012, 12:46 PM
The 747
What have they invoiced you for?
21st May 2012, 12:50 PM
KRISTOFFA
they are actually a gift, father inlaw owns the shop, so im not worried about cost, just asking more so, would i be better getting 15s for more sidewall and stuff, or return and get a 16? or better yet, would a 15 even fit over my brakes, i dont want to mess around getting them out of the box and scratching them up if im going to end up returning if you know what i mean. Cheers
21st May 2012, 02:27 PM
Moderator
Send them back.
15s will fit over your brakes unless you have a 4.8 then no chance.
16s give a bit more room around the brakes regardless and i like the extra ventilation that room gives tot he brakes in the bush. Less likely that the Mud will get jammed in there either with a bit more room.
Go the 16s
Check out my Toy -->
Rogue Dung Beetle
21st May 2012, 03:20 PM
Legendary
consider the cost of tires as the 16s are probably more common and cost less
2007 GU 6 /ST-L / MYO8 / DIESEL/AUTO /MOONSTONE /pro vent 200
OH LEATHER IS NICE
21st May 2012, 03:59 PM
Go to the 16".. Think future. NO one will want 15" rims in 5 years time when you want to sell them or put them on a different car. I would def change them if I could.
Scotty B | Take it Off Road or Take it Back
3.0L GUIV 2005 - TIG Welded Intercooler, NADS, Redarc Dual Battery, Additional rear power socket, 2" Lift (Ironman constant load foam cell), Electronic Trailer Brake Controller, Steel Bullbar, 12,000lb Winch, UHF
21st May 2012, 05:53 PM
Thanks for the feedback guys. Much appreciated
21st May 2012, 11:08 PM
Hardcore
I thought you still need to run a different offset to run 15 inch rims on a GU ???, GUs are bad enough at getting wobbles without changing wheel offset (lol)
22nd May 2012, 12:32 AM
Ive decided I'm going to return them, so to make sure I have everything right, what do you guys recommend for 16s, 16x what? and what offset?
22nd May 2012, 10:15 PM
Width and offset are really dependent on what size tyre you plan on running? Also it's a good idea when shopping for steel wheels to splurge a bit and get the decent ones such as the ROH Trax. Chinese steel wheels are very wobbly. I'm not just saying that cos they are chinese, It's just a fact. I'v had multiple set through work that we have sent back, You wouldn't even put them on your trailer.
