Results 1 to 8 of 8
Thread: Flywheel Bolt Torque
    Oct 2010
    Hi Everyone,
    Can someone please tell me the torque setting for tb42 flywheel bolts,
    thanks
    Expert Chops's Avatar
    Oct 2010
    This should be what your looking for.
    Attached Files Attached Files
    1984 MK Anniversary Model, LWB,SD33,Air-Con,P/S,Straight Body,Minimal Rust.........Not Bad For Free
    Oct 2010
    just use a rattle gun ive had no probs but mind you im also a mechanic
    Feb 2013
    that pdf is actually the clutch plate bolts not the flywheel.. i search the entire service manual and there is no torque settings.. all the info it has put engine oil on the bolts before putting them back ... ill go with the rattle gun or breaker bar.. cant go wrong..
  6. #5
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Quote Originally Posted by chilenito View Post
    Welcome 2 the forum chilenito, please head over to the introduction section and tell us a little about yourself and your rig.
    Todd
  7. #6
    Thomastown, Melbourne
    6 Post(s)
    Gee you signed up in 2010 .... and all of 2 posts.... funny bugger!!!
  8. #7
    The master farter
    mudski's Avatar
    460 Post(s)
    Quote Originally Posted by Bloodyaussie View Post
    Which one's the funny bugger? andy san or matty? Both signed up the same time and both with a two posts?
  9. #8
    Apr 2011
    Mandurah, WA
    the flywheel torque is on the engine mechanical page, EM-31. its 147-167 Nm (15-17 kg-m, 108-123 ft-lb)
    no mention of thread lock which was new for me, but also a lot tighter than others i've done.
  10. The Following User Says Thank You to melts For This Useful Post:
    gibbogillett (23rd April 2016)
