16th May 2012, 02:40 PM
Yea will do mate
"Gunter" - 1993 Nissan Patrol GQ DX II, 6cyl 4.2L Diesel. 2" Lift EFS suspension. 33" Mickey Thompson MTZ (285/75 R16). Warn Winch
16th May 2012 02:40 PM
16th May 2012, 06:57 PM
So I got the Tyre back and the only thing wrong was mud in the bead that stopped it from sealing. :banghead:
All fix now though.
16th May 2012, 07:12 PM
next time lay the tyre on the floor and hose it so all the bead has water pooling on it and you will see bubbles if it is the bead.
you can use a high lift jack or tyre bead breaker or just drive on the tyre makeing sure you dont hit the rim! (easy with 2 ppl as the tyre will want to slide some times) to pop the bead off then clean it out yourself shouldnt take any more then 20 mins. just make sure you remove the valve first also.
The Following User Says Thank You to megatexture For This Useful Post:
