Results 1 to 10 of 15
Thread: Gear box, problems selecting gears
    Jul 2012
    I have a 2001 4.2 D. New to me. 160.000ks.
    I have had nothing but trouble changing gears.
    After removing the top cover of the the gear box i found that the gear stick has play in all directions.
    I sent my mechanic for a test drive in it and he also said its not right.
    After removing the stick i found 2 half nylon type bushes.
    The locating pins in the bottom half are loose and wobble, the small nylon bush on the botton of the gear stick is also loose and wobbles, under the bottom half of the bush which is in the gear box is a spring.
    My question is how do i remove and replace the top half of the bush on the gear stick.
    The id seems to small to slide back up the gear stick. It cant fit over the ball joint on the G/S.
    This is the part that has a rubber insert between the bottom of the G/S and the top part.
    If i pull the rubber housing off the G/S will the top half of the bush slip over the gear shift.
    Thanks in advance for any help.
    Whilst its out have you thought about putting a short shift kit on it??
    Watching this post for instructions as I'm in the same boat.
    You may find the bush might be 2 half bushes so once everything is removed they will come out. I havent ever had one apart so this is kinda a shot in the dark.
    Jul 2012
    The bush is in 2 parts. a top half bush and a bottom half with 2 pins sticking out from each side.
    These pins locate the G/S.
    The bushes are in one piece they are not split.
    The top half sits on the ball on the G/S, the bottom compresses against the ball on the G/S.
    This pressure is created by the spring in the gear box.
    Removing the bottom half and spring is an easy task.
    But the top part can only come off in one direction and that is up due the the ball on the G/S.
    Just wondering if it will fit over the rubber vibration joint.
    Ill get the vernier out tomorrow and see what the sizes are.
    I shall return with the answer.
    Thanks.
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    optic and choochie, introductions would be nice, the intro thread can be found in my signature
    Todd
    Jul 2012
    Sorry about that i missed it when joining.
    I have just done as you rightly suggested.
  9. The Following 2 Users Say Thank You to optic For This Useful Post:
    MC97GQ (6th July 2012), NissanGQ4.2 (6th July 2012)
  10. #8
    Aug 2010
    17 Post(s)
    Optic, I have moved this to the gearbox section of the forum.
    Todd
  11. #9
    Jul 2012
    Well after looking at manuals, i was still at a loss as to find out how to fix my problem
    I rang my mechanic this morning and he said the parts had arrived.
    My first question was about the top bush.
    This was his reply.
    The top half bush comes already fitted the the new gear shift lever. Yes brand new Nissan gear shift lever.
    Then he tells me a price which had me screaming out its HOW MUCH.
    Its all to be fitted in an hour so ill up date the final costs after its been fitted.
    Fitting should only take 5 minutes as the bottom just lifts out.
    However the parts are going to be the killer.
    There must be a cheaper supplier of Nissan parts in Melbourne some where.
    Can some one point me in the right direction of a supplier.
    For anything i may need in the future.?
  12. #10
    Hardcore the ferret's Avatar
    Sep 2010
    on the coast W.A.
    Parts for Nissan www.nizzbits.com.au Genuine at the best prices, Garry has looked after Me many times.
    Cheers, the ferret.
