12th May 2012, 04:52 PM
Help removing ZD30 turbo heat shield...
I want to remove the heat shield as from underneath I can see black soot marks against the motor and the inside of the shield. So I want to check this out. Is there any trick to removing it? I got it all unbolted bolt it looks like the heater hoses need to come off. Plus the steel heater tubes too but don't want to remove the tubes as I will need gaskets to put it back on. So before I start stripping it all down. Do you think the heater pipes, and hoses need to come off?
Thanks.
12th May 2012 04:52 PM
12th May 2012, 06:35 PM
How's the serenity
Hi mudski , no the heater hoses or pipes do not have to come off . your turbo actuator and bracket does . It will come out foward and downwards . If you dont shed any skin during the ordeal you have done extremely well .
The price of excellence is dicipline , the cost of mediocrity is dissapointment .
The Following User Says Thank You to boots For This Useful Post:
12th May 2012, 07:23 PM
Thanks mate. All done and NO skin shed. To my surprise the top stud is completely missing from the turbo to the exhaust pipe :O
14th May 2012, 04:01 PM
Wish I knew that the other day, ended up cutting my off!
15th May 2012, 06:09 PM
Holy moly! But i had the same thought too. While I'm at it the pryo fitting is getting welded in, just gotta decide above or below the cat. Also the cat's going on a diet
15th May 2012, 09:51 PM
How's the serenity
Attachment 16219 Hi mudski , heres a pic of my egt sender install
15th May 2012, 10:10 PM
Thank you so much for all your help boots.
15th May 2012, 10:17 PM
How's the serenity
Any time mate , thats what this forums all about .
13th January 2015, 06:29 PM
Hi Mudski, Did you find out what was causing the "black soot marks against the motor and the inside of the shield". I noticed the same on my car while cleaning the engine bay last night, but other than your post, I couldn't find a thread on the forum explaining what causes it and how to fix it.
2011 GU Patrol ST ute, 3.0L CRD
13th January 2015, 06:58 PM
Its the turbo to dump pipe gasket mate. I fixed it all back then but its done it again. The exhaust studs are working loose I reckon.
clawrence (13th January 2015)
