Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Suspension advice for a G60
    Wink Suspension advice for a G60
    Hi,
    I was wondering what is in a full suspension kit for a g60 patrol.
    Thanks wesvo
    Also
    Can mq patrol suspension kit fit on a g60 patrol swb model, also with the kit should come with coil springs
    Expert dan&tamspatrol's Avatar
    brisbane
    depends on how high you go higher lifts need more gear
    Just like what comes in the kit like shocks shacle bushes ubolts pins power steering steering damper, thats all I can find on a g60 patrol suspension I want to know what else is excluded
    brisbane
    mate im not quite sure so hopefully one of the gurus on here will be more help
  6. #5
    brisbane
    330 Post(s)
    Quote Originally Posted by Wesvo View Post
    Hi,
    Thanks wesvo
    Quote Originally Posted by dan&tamspatrol View Post
    Yeah mate basically your question cant be answered unless you know how high you want to go as Dan&tam asked.
    If you go a 2" lift the springs and shocks only
    or
    you could probably get away with just a Shackle lift for a 1 to 2" lift.
    There is all sorts of ways to go with a leaf sprung G60.
    What do you want? how High do you want to go and what are you using it for?
  8. #7
    330 Post(s)
    Hi,
    I am not sure if the will be interchangeable but neither will be with Coil springs and both will have Leaf springs which will be fine Old School bud, tough old truck
  9. #8
    Ah just a 5Omm lift that's all I can find the steering damper, shacle bushes, pins, shocks, shackles, ubolts and find it hard to find What else I need for the suspension kit
  10. #9
    If you can tell me what comes in the full kit, or find one that comes with full kit in some brand that's new
    Exclamation G60
    Hi,
    Where can I find aftermarket suspension for a G60 patrol
