7th May 2012, 09:15 PM
Suspension advice for a G60
Hi,
I was wondering what is in a full suspension kit for a g60 patrol.
Thanks wesvo
Also
Can mq patrol suspension kit fit on a g60 patrol swb model, also with the kit should come with coil springs
7th May 2012 09:15 PM
7th May 2012, 09:17 PM
depends on how high you go higher lifts need more gear
7th May 2012, 09:26 PM
Just like what comes in the kit like shocks shacle bushes ubolts pins power steering steering damper, thats all I can find on a g60 patrol suspension I want to know what else is excluded
7th May 2012, 09:55 PM
mate im not quite sure so hopefully one of the gurus on here will be more help
7th May 2012, 10:15 PM
7th May 2012, 11:17 PM
Moderator
Wesvo
Hi,
Thanks wesvo
dan&tamspatrol
Wesvo
Yeah mate basically your question cant be answered unless you know how high you want to go as Dan&tam asked.
If you go a 2" lift the springs and shocks only
or
you could probably get away with just a Shackle lift for a 1 to 2" lift.
There is all sorts of ways to go with a leaf sprung G60.
What do you want? how High do you want to go and what are you using it for?
Check out my Toy -->
Rogue Dung Beetle
7th May 2012, 11:40 PM
Moderator
Wesvo
Hi,
I am not sure if the will be interchangeable but neither will be with Coil springs and both will have Leaf springs which will be fine Old School bud, tough old truck
Rogue Dung Beetle
8th May 2012, 08:18 AM
Ah just a 5Omm lift that's all I can find the steering damper, shacle bushes, pins, shocks, shackles, ubolts and find it hard to find What else I need for the suspension kit
8th May 2012, 08:20 AM
If you can tell me what comes in the full kit, or find one that comes with full kit in some brand that's new
8th May 2012, 05:18 PM
G60
Hi,
Where can I find aftermarket suspension for a G60 patrol
