6th May 2012, 02:42 PM
Hardcore
2" body lift
whats the best 2'' body lift poly, aluminium?? as im going a gu 2" lift on my gq as well i've got a manual is there anything else i would have to look at doing as well
6th May 2012 02:42 PM
6th May 2012, 03:12 PM
Moderator
at least 70mm diameter Poly blocks mate and it will be fine.
Extend your diff breathers, check your gear box breather on the way up to.
Relieve the clutch vac line connected to the chassis rail on the left side near the fire wall.
Relieve the steering column rubber uni by slipping it down the column to flatten it out.
Slot the back of the Low range stick floor opening to allow for selection of Low range.
Watch out for the lower cowl on the radiator as it may need adjusting for the fan to operate. I have never had to do this and have done 5 or 6 BLs already but i have heard of plenty that have.
Check out my Toy -->
Rogue Dung Beetle
The Following User Says Thank You to MudRunnerTD For This Useful Post:
growler2058 (6th May 2012)
6th May 2012, 05:46 PM
Hardcore
6th May 2012, 05:52 PM
Hardcore
i've already got diff breather kit but i cant find where it goes does anybody have photos up so i can see or can someone send pics
8th May 2012, 07:42 PM
what kit fo you have piranha?
28th May 2012, 05:07 PM
Hardcore
ok so i've orderd my 2" body lift and getting a bar that suits the lift. What do i need to do to make things fit?? as i understand brake lines dont come into affect by a 2" BL gotta drop the rad and alter the hi/lo shifter (can i just gut the floor abit)?? is that all?? and whats the best way of fitting the blocks in??
28th May 2012, 10:36 PM
Moderator
Read my post again
MudRunnerTD
Rogue Dung Beetle
29th May 2012, 10:56 AM
I havent moved the radiator in mine and have no issues with the cooling side of and the fan doesnt foul. One thing i did do was shorten the lower radiator hose as it looked like it nearly had a kink in it.
30th May 2012, 03:22 PM
Hardcore
9th June 2012, 08:46 PM
I take it that the same issues to keep an eye on with the GQ with a lift would be the same across the board?
Whoever disagrees with the saying "Might is right" obviously doesn't own a MQ
