Page 33 of 33 FirstFirst ... 23313233
Results 321 to 326 of 326
Thread: Deaths from towballs
  1. #321
    SUCH IS LIFE Maxhead's Avatar
    ACT
    36 Post(s)
    And then you get people making their own points which is scary!
    WTF?????
    Those yanks are definetly special
    ................on the road
    ________________________
    ______ 2017 D-Max _______
  2. The Following User Says Thank You to Maxhead For This Useful Post:
    GQtdauto (6th June 2019)
    Beginner Greytd28's Avatar
    Jun 2017
    $50 sounds like a bargain 👌🏻
  5. #323
    Expert Mike02Ti's Avatar
    Jun 2016
    Rockingham WA
    4 Post(s)
    Im a certified advanced rigger /dogman. What we are taught as a certified rigger in Australia is to attach a shackle hand tight then back it off 1/4 to half turn. This is done regardless of the size of the shackle. The reason for this was explained by an old rigger with 40 yrs experience who taught me was to stop the threads binding under load and not being able to release the pin at all.
    All gear is to be inspected before use obviously. This includes the shackle itself. It should not be warped/ bent or elongated in any way. The pin should be straight and threads in good condition.
    It is also good practice for the shackle pins to be moused. To prevent the pin either coming undone or in result of a catastrophic failure bits flying all over the joint.
    Yes i have seen them fail but its extremely rare. However i have started to see many eye bolts pop up lately on bull bars and rear bars. No way in hell would i use them. Any kind of side load and they ping off. Even the wide base ones. Think about it.... whats a tow ball shaped like? Looks kinda like an eye bolt without a hole though the guts of it huh.
    Like the evil twin said and i agree with him. Its one of my pet hates seeing a couple of 4.7 ton shackles hanging off the recovery points. What are they there for in suburbia? Do you know how much damage it will cause if one come off and slid across the road and got kicked up by a tyre?
    Personally i hate D shackles and will never use them. I always use a bow shackle. They are a bit wider to fit your slings on and can disperse the load over a slightly wider area of the shackle itself. D shackle should only be pulled in 1 direction which is straight.
    When i first started getting into 4x4 i was appalled by the practices that many people are guilty of. Some have no clue, some have no care to learn and some just dont have common sense or an interest in self preservation.
    I would love to know how many people throw their snatch strap in the bin after 4 or 5 recoveries too as that is what is usually recommended from what i have read.
    2002 GUIII Ti 4.8
    Details here
  6. The Following 5 Users Say Thank You to Mike02Ti For This Useful Post:
    DX grunt (25th June 2017), GQtdauto (6th June 2019), MB (23rd June 2017), MudRunnerTD (23rd June 2017), PeeBee (23rd June 2017)
  7. #324
    97 Post(s)
    What a brilliant idea
  8. The Following 2 Users Say Thank You to Clunk For This Useful Post:
    GQtdauto (6th June 2019), MB (24th June 2017)
  9. #325
    Jun 2019
    Oh my god...
  10. #326
    Jul 2015
    Camden NSW
    6 Post(s)
    Quote Originally Posted by MudSlut View Post
    What about those "Recovery Hitch tongue with shackle" type things that go into where your tow ball tongue goes and uses the pin to hold it in place? are these just as dangerous? Is it the "Pin" that is letting go or or ball snapping off the tongue?
    A steel "pin" of that size/diameter & length is incredibly strong. The real danger is in using the ball as the connection, as they are not designed as a "shock point".
