Page 23 of 36 FirstFirst ... 13212223242533 ... LastLast
Results 221 to 230 of 356
Thread: Deaths from towballs
  1. #221
    Expert kind's Avatar
    Nov 2013
    brisbane
    No mate not at all. That is a factory tie down point only and is designed to be used during shipping from Japan and if your car ever needs to go on a flat bead (touch wood)
    Under No Circumstances should you every use it in any form of recovery.
    Stay safe and thanks for asking.
    Ok thanks I didnt think so but saw someon with shackles on so thought I would ask. Also is this a factory recovery point from the looks?
    1996 GQ 2.8TD 3" straight though, draws and oh so much more
    Quote Originally Posted by kind View Post
    Cheers mate,
    Ys that is a pic of a Factory Nissan Recovery point. I use this on the front of my GUIV without hesitation. I have read stories though of them straightening out but am yet to see a photo of one that this has happened to and am not sure if its a wives tail or not mate. I use it.
    Note*** I also try my best Not to get Stuck. When I do I consider the Maths before attempting any recovery.
  4. #223
    Nov 2013
    brisbane
    Cheers mate,
    Yeah thats why im asking I have never had to be recovered from the front cause im always the first one in haha
  5. #224
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    sometimes you cant get in front of the bogged vehicle and you cant turn around so you have to do a reverse snatch. Ugly but sometimes necessary
    Hello from Under Down Under!
  6. #225
    Expert patrol2.8's Avatar
    Nov 2011
    vic
    Well its simple then... darwinism should come into play soon and you dont want to be near them.. Explain it once and how you are not telling just to make yourself look the know it all but for there own safety, if they take heed then good on them and well done but if they dont then...GET STUFFED!!!!!!!
    Agree with you but its still bloody hard to turn away cause that thought goes through ya head what if I read about one of these guys getting belted in the head by a the ball in the morning paper
    Theres only one thing tougher than my truck............. YES DEAR GOING TO DO THE LAWNS NOW
    WARNING: Towballs used for recoveries,can and do kill people and damage property
  7. #226
    Patrol Guru rottodiver's Avatar
    Nov 2011
    Perth
    ImageUploadedByMotorculture1386195736.853220.jpg here is a pic I found a while ago, make what you want of it, I have posted it before. I believe the front hook is fine for recovery but like everything there are rules and it seems no side loading at all which is always hard to achieve when doing a recovery.... For what outback ideas charges and considering the quality of his recovery points they are almost a no brainer....
    His points are brilliant...
    Scotty
  8. The Following 2 Users Say Thank You to rottodiver For This Useful Post:
    MudRunnerTD (5th December 2013), threedogs (5th December 2013)
  9. #227
    Quote Originally Posted by rottodiver View Post
    Scotty
    Thanks Scotty,
    I Note that they specifically state towing from Sand, Mud and Snow which i would consider for Snatch type recoveries so all is good. The reason they say not to undertake general Towing from this point is that the "Tow strap" can come off the hook as it is not a closed hook and can be dangerous.
    I note that there is a hole other debate about the suitability of the Nissan Recovery points and i certainly use an Outback Ideas rear recover tow hitch on both cars that has seen a heap of work.
  10. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  11. #228
    461 Post(s)
    You ever removed the rear oem loop and seen how its held together? I was quite shocked to say the least.
  12. #229
    Just to touch on the rear loop I know they weren't allowed on vic comp trucks
    as is but I believe they could be used if they were welded on the other side.
    But again no idea what swl or wwl you would achieve, similar with the front hook
    some clubs allow them others don't, they do break and straighten but not as often as ppl think.
    Like ALL recovery items they need to be checked and replaced if they look IFFY, this includes shackles , hooks ,
    snatch blocks. Best thing would be do a recovery course so you can pass on good information to others who
    may be "green" when it comes to this. We all have to learn at some stage and continue to learn, so stay safe
    only one person directing the recovery ,please
  13. The Following User Says Thank You to threedogs For This Useful Post:
  14. #230
    Patrol Freak liftlid's Avatar
    Nov 2010
    6 Post(s)
    Yes looks can be deceiving, the reality is that if you did manage to damage a factory point you are doing your recoveries wrong! You might have also damaged the chassis as well.
  15. The Following User Says Thank You to liftlid For This Useful Post:
