2nd May 2012, 11:11 AM
Door locking assembly
Hey all, having serious problems with my drivers side door, seems the lock assembly doesn't do what it should. And when I open the door handle, when all doors are locked. It just opens up all doors but not the drivers. And the drivers is stuck shut. Pulled the assembly apart and found some crap looking springs.
But just wonderin were I can get a whole new assembly from? None on eBay.
2nd May 2012 11:11 AM
2nd May 2012, 11:29 AM
Depends where you are located and what model i guess i threw the complete doors out on the last gq i had for parts.
6th May 2012, 07:39 PM
When I have a problem with the locks on my Y60, always first try this:
1. Spray WD-40 into lock.
2. Wait 10 min.
3. Spray lubricant spray into lock.
4. Several times, close and open the lock
sometimes it is enough to lock trouble
7th May 2012, 12:30 PM
I got a similar problem with my GU, the drivers door locks and does not unlock even though I can hear it trying to . I have to use the key on the pass side as no doors open and force the drivers side internal button open.
7th May 2012, 10:02 PM
Yeah fity. Same kinda thing, I have worked it out to be a spring in the switch mechanism, The one all the pull rods and so forth go to. So after calling a few wreckers and no response. I think I'll just get the part from Nissan.
Had the same problem, when I used to mod subarus. Yet they have a bolt/scew set up.
To be honest, not looking forward to the price for a simple part!
I have tried the inox and lanolin based products but it's past that... Alas
