Results 1 to 4 of 4
Thread: Clutch to suit TD42
    a member of the menagerie MC97GQ's Avatar
    Jun 2011
    Nimmitabel in the deep, deep south of NSW
    Clutch to suit TD42
    Hi all time to pick your brains regarding a new clutch for in my truck,
    I am about to swap my gearbox with one from a TB42 Maverick now I know that I will need to swap my bell housing off my gearbox on the TD42 but my question is are the clutches the same between the TB42 and the TD42,
    I am looking at the Exedy safari Tuff clutch to replace mine and need to know if I order one for a TD42 will it fit in with the different gearbox.
    All help, theories and advice on my choice of clutch would also be appreciated,
    Mark
    Proud former owner of a 1997 White GQ TD42 Patrol Cab Chassis with an after market turbo, now with over half a million k's and still going strong, that's had a heart transplant and now not owned by me
    I was told the safari clutch was 2 heavy on the pedal unless your car has the clutch booster.
    I went with the exedy heavy duty behind a td42 turboed no clutch booster myself as advised and so far so good even towing an extra heavy load up steep hills without a problem.
    581 Post(s)
    I have the Exedy tuff and I don't think I have a booster. It's not my daily driver and I was told if it is your daily than you should go for Exedy heavy duty but I find the Tuff Clutch fine to drive around town. I absolutely love it for heavy loads and the camper....
    Expert bordertech's Avatar
    Bordertown
    Same gearbox, yes it will fit. Even the TB42 and TD42 engine blocks are almost identical.
    I love terra firma - the less firma the more terra
