30th April 2012, 06:25 PM
Where's My Oil Gone!
OK, so i checked my oil the other day and found that it is down on the stick,
-the car does not blow smoke
-the car has no oil leaks
-there is no oil in the radiator
im getting confused as to where the F#@* my oil is going.
its in a 99 gu ute 4.2 deisel
30th April 2012 06:25 PM
30th April 2012, 10:32 PM
Check the oil three times in one week. Always cold in same spot on driveway. See what readings you get. Vecosity (thinness)changes with heat. That changes amount in engine by a percentage.
Tim
1st May 2012, 10:24 AM
What sort of oil are you using Kingy, and are you using any adatives.
The reason I ask this is because i had the same prob a couple of years ago after using delo 400 with the prescribed amount of nulon oil treatment in my gu2 zd30.
I went from using no oil to using about 1/2 a lt every 1000 ks. In the end I didnt know if it was the oil or the treatment so I drained my sump and changed the brand of oil I use and now it never uses a drop between 5k services.
1st May 2012, 01:09 PM
Atm I'm using nulon 10w 40 with no additives
1st May 2012, 01:25 PM
How many kms on it?
Engines will use a bit when they get older.
My gq petrol is getting a bit old and uses about 150ml a month. No drama, just the rings getting worn I reckon and a few tiny leaks. But it's great because if I keep it topped up I know the oil is fresh hahaha!
Tap, crackle, pop
Hello from Under Down Under!
1st May 2012, 01:51 PM
I run shell rimula 15w-40 in both my 4.2s no additives and never have an issue. If it is burning oil cos of wear your exhaust gas will have a slight blue colour about it. Does she run sweet temp wise?
1st May 2012, 04:47 PM
Yeh doesn't blow any smoke, never gets hot, only 214000km on it
1st May 2012, 06:28 PM
45/70
may i ask what brand oil are you using now? is it as 'quiet' as delo400?
2nd May 2012, 10:39 AM
Hi Trol3.0.
At the moment I am using the genuine semi synthetic oil from Nissan, but due to it now costing around $60 for 5lt I am going to swap over to Penrite 10 Tenths premium 0w-50.
It is a full synthetic and is about $70 for 5lt at autobarn and will allow me to go from 5k to 10k services so its a better oil and it works out cheaper in the long run.
Here is the Data sheet.
http://www.penriteoil.com.au/pis_pdf...FEB%202012.pdf
