29th April 2012, 08:41 PM
'97 GU 'Troll Questions
G'day Folks,
Has anybody on the Forum from the Adelaide area replaced their standard Aux fuel tank with a 78 ltr replacement tank from 4wd systems. If so was it easy enough to do yourself ?
I'm getting the Auto Lokka installed and was looking at getting a replacement tank as well, if the tank is easy enough to install ( Can be done in a day ) I will do it meself.
Many thanks.
29th April 2012 08:41 PM
30th April 2012, 12:51 AM
Moderator
Pretty easy job mate, you will do it in a day by yourself no probs, unbolt, drop it, un plug and install in reverse.
**Side note.
You will find you will get better responses if you put the subject of your question in the thread title mate, "97 GU Troll Questions" is probably a bit vague? If you had put a title like "fitting a long range Sub Tank into a GU?" you may have got a bit more traffic through your thread. Your question has the same answer for a 1997 through to 2012 GU mate so dont limit yourself.
All good bud, here to help mate. Cheers.
Check out my Toy -->
Rogue Dung Beetle
30th April 2012, 09:32 AM
No worries thanks for the reply.
Still learning how to word subjects on forums.
30th April 2012, 06:27 PM
Moderator
All good mate, enjoy the forum. The more specific the question the better the answers will be
Rogue Dung Beetle
