27th April 2012, 02:14 PM
#11
27th April 2012 02:14 PM
27th April 2012, 02:24 PM
#12
The 747
What is the input on them?
27th April 2012, 02:28 PM
#13
RIP - valued member and true gentleman of this forum that will be missed by many!
G'day Tweaked, I can't see a link in your post?
Kris, if there isn't room for a surface mount female ciggy plug, you can get female ciggy plugs that do not need to be surface mounted, they just go onto the end of the wire - like a house extension lead. You could just let that rattle around in your console.
You'd think there would be surface mounted ciggy and USB female plugs available - maybe that is what Tweaked is keeping us in suspenders about :-)
"As a boat owner and a four wheel drive owner I feel like a pelican: every where I look I see a big bill in front of me”
27th April 2012, 02:34 PM
#14
The 747
Tweaked's second post worked haha
27th April 2012, 02:37 PM
#15
That looks nice and neat Tweaked. What is the max amp draw through it combined? Would it be safe to simply beef up the original fuse for the ciggy lighter or would it be better to re-wire it in?
tappin it
Hello from Under Down Under!
27th April 2012, 03:08 PM
#16
Yea sorry about that it didnt come up in my first post stuffed it up
Here is some specs on it:
1 x Dual USB Sockets univeral charger.
1 x Ciga Socket
Compatible for all generation apple iPhone, iPad and iPod
LED indicated power ON
Black colour PVC casing
reverse polarity fused protection
Specification
Input Voltage: 10-20v dc
Input power protection fuse: 2A
Max output power: 1Amp
Max charging output 2 x iPhone, 2 x iPod or 1 x iPad
Surface Mount
C/W PVC housing
Designed for heavy duty use
Specially designed power socket to suit 2 USB powered devices & additional cigarette lighter socket
I personally would wire up seperate to the factory cig. I have different combinations of these available as well
27th April 2012, 03:14 PM
#17
The 747
Have you got something like that which also has a USB input? Would be perfect if you do.
Tappa tappa
27th April 2012, 03:58 PM
#18
could one of the usb sockets be rewired to accept the usb extension from the headunit?
Teno's Troll...
08 CRD ST. 2" lift, 33' Maxis Bighorns, Snorkel, ARB Deluxe Bar with Foggies, 12000lbs Avenger Mako TDS with Synthetic rope.
27th April 2012, 11:00 PM
#19
I will see what I can find for you mate
27th April 2012, 11:26 PM
#20
The 747
Cheers mate, appreciate it.
