Results 1 to 2 of 2
Thread: Gq patrol coil voltage
    Beginner Fuddled's Avatar
    Adelaide
    Cool Gq patrol coil voltage
    Hi guys I'm having problems with my tb42 backfiring I fitted pertronix 2 and extended rotor button it's running a gt40r coil with ballast at back of ballast I was getting 13.8 and at front 12.8 and same on coil what voltage should it be could this be my problem thanks guys
    Ford maverick lpg,2inch lift,2inchbodylift,roof rack ,draws,inverter,dual batteries,pertronix2,extendedrotor button,snorkel,extractors 2.5 exhaust
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Yes, Those are around the voltages I would expect to see when using a voltmeter, with the engine running.
    A voltmeter is to slow at reading the rapidly changing voltage at the coil, it will just display an above average reading.
    To get an accurate reading you will need to use an oscilloscope.
    The 13.8 volts to your ballast resistor is good.
    I would be double checking the timing, spark plugs, leads and cap before replacing the coil.
    Something else to try is, disconnect all the extra wires from coil such as tacho and radio suppressor.
