Results 1 to 10 of 13
Thread: GU Body Dimensions and Specifications
    581 Post(s)
    Another member has given us a great little document.
    Full detailed plans of the Nissan Patrol Y61/GU body dimensions including all frame work dimensions, parts and all types of plastic, steel and coated dimensions and identifications.
    Loads of pictures, scales and measurements of everything!
    Also inclues lifting points, basic service information and electrical components.
    Enjoy!
    Attached Files Attached Files
  2. The Following 10 Users Say Thank You to AB For This Useful Post:
    BAU (30th August 2020), BorisGU (26th March 2019), damianovdd (12th March 2011), Gerrit Loubser (25th September 2011), guZombie (21st January 2014), Gyro (3rd January 2022), hutchy84 (16th January 2012), ozzymalone (12th April 2012), pascal1 (17th June 2013), Ruby (3rd April 2011)
    WA Wheatbelt
    23 Post(s)
    If you're taking requests..... any info on a 2005 GU ute? Thanks.
    Nov 2010
    Thankyou for the pdf :-)
    Expert damianovdd's Avatar
    Sofia, Bulgaria
    Thank you for the doc AB.
    GR; Y61; 1998; RD28TDI; MANUAL TRANSMISSION;
    Apr 2011
    Thanks for the PDF
    Sep 2011
    Broken Hill - Far West NSW
    Thanks for the PDF
    Expert hutchy84's Avatar
    Nov 2011
    South Yunderup W.A
    Thank AB info is gonna come in handy as im rebuilding the front of a GU
  10. #8
    Advanced Bakes's Avatar
    Jul 2011
    Townsville, QLD
    Thanks AB. that will be handy :-)
    2006 4.2TDi GU Cab Chassis - Twin Locked with extra....stuff
  11. #9
    Advanced Timrob's Avatar
    mount warren park qld
    thanks AB
    cheers
    2000 GUII 3.0td, Narva spotlights, blackwidow draws, GME uhf, turbo timer, 60lt waeco, 32" at, snorkle
    A bad day 4 wheeling is better then good day at work
  12. #10
    Expert ozzymalone's Avatar
    Aspley, QLD
    Cheers AB!
    SPEED METAL NEVER WENT AWAY>>>>> ONLY OUR HEARING DID!!!
