20th April 2012, 12:03 PM
Anchor points
Hi all,
Can anyone give me some information on my GU Patrol with anchor points on the front and rear end. Are the standard ones sufficient or is it safer to add a higher rated one.
Thanks John
20th April 2012 12:03 PM
20th April 2012, 12:29 PM
RIP - valued member and true gentleman of this forum that will be missed by many!
Lots and lots of opinion on this issue John - try searching on Recovery Points. Doubtless some of the more recent members will have something to say, too
"As a boat owner and a four wheel drive owner I feel like a pelican: every where I look I see a big bill in front of me”
The Following User Says Thank You to Silver For This Useful Post:
Superoo (20th April 2012)
20th April 2012, 12:55 PM
I recently started a thread on this topic, see below
http://www.nissanpatrol.com.au/forum...ecovery+points
As silver suggests try searching too, there's a bit out there.
Cheers,
Rusty
The Following User Says Thank You to Rusty86 For This Useful Post:
20th April 2012, 01:18 PM
G'day John. I suspect you mean the "tow" hook at the front. Some have fitted after market recovery brackets but many use just the hook. If you have a HR towbar then most people use the pin as the recovery point although you can buy a billet insert. The "anchor" points are for tie down only and NOT for recovery. Hope this helps.
GU1 Auto ST4500 lpg/petrol.
The Following User Says Thank You to twisty For This Useful Post:
20th April 2012, 10:54 PM
Yeah GU's look good with anchors holging them down in the surf. Hahahahahahahaha.
Go the old Real Patrols G60 MQ/MK. PML!!!!
Tim
20th April 2012, 10:59 PM
The QNPC uses the factory recovery point in Driver Awareness Program as a rated recovery point. When you think about it, that big thick hook (specifically designed as recovery point) against the thinner pin in a rated shackle, hich one is stronger?
But don't get confused with transport tie down points.
Tim
The Following User Says Thank You to Finly Owner For This Useful Post:
Superoo (21st April 2012)
20th April 2012, 11:16 PM
Finly Owner
Oh Timpicking on GU's ... easy target. uummm ... oh yeah, well, GQs' are ... I got nothing.
