20th April 2012, 06:31 AM
Fuse box location
I cann't find fuse box in my car; 2.8TD. Could you help me?
20th April 2012 06:31 AM
20th April 2012, 08:41 AM
Drivers side kick panel has a door that comes off.
Right near the bonnet cable.
The Following User Says Thank You to 97_gq_lwb For This Useful Post:
Bodek G (20th April 2012)
21st April 2012, 10:37 PM
yep like 97 says & the other mains are next to battery & relays are under metal plate beside main battery driver side of it
Got the baby GQ a 1997 2.8TD RX Wagon Racetech EGT & Boost Guages Dobinsons coils 32in BFG KM2 M/T
22nd April 2012, 12:02 AM
Hi. I can back up the previous replies. I have also come across a few in line fuses tucked up under the dash and inside the drivers side kick panel so...I guess it depends what isn't working as to where you search. Having said that, I think most issues would be with the most obvious and easy access ones. Cheers.
15th April 2017, 01:46 AM
Hey does anyone happen to knpw what fuse cobers the map/spot lights? Tryong to put LED globes in there and nothing seems to wprk and i can't find witch fuse it is in the owners manual
15th April 2017, 08:20 AM
I'm sure it has its own fuse , will check mine after my morning hangover cure .
15th April 2017, 08:59 AM
Thinking it must be the fuse marked " clock , room " , if that's the case is your clock and interior lights all working ?
7th June 2020, 06:15 PM
I can't find the engine fuse Nissan patrol 2014
Plz help me
