Page 3 of 22 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 211
Thread: XR6T into GQ conversion
  1. #21
    Expert twase's Avatar
    Campbelltown NSW
    Might have solved the turbo clearance problem by flipping the manifold so the turbo is now high mounted. However I might now have bonnet clearance issues.
    The other issue is the cast iron dump pipe no longer points in the correct place but there seems to be plenty of options here.
    Campbelltown NSW
    In the light of day it looks like I am missing 50mm or so of bonnet clearance won't be able to tell for sure until the motor is installed.
  4. #23
    Campbelltown NSW
    The more I look the less likely its going to fit under the bonnet, might have to go chasing a FG manifold.
    1990 Ford Maverick LWB - BA XR6T powered.
  5. #24
    North brissy
    2" body lift? Bonnet scoop over turbo?
  6. #25
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Or a bonnet bulge of a ford? That would look different on a patrol
    tappin it
    Hello from Under Down Under!
  7. #26
    Campbelltown NSW
    food for thought, not sure that it would fit the patrol image though.
  8. #27
    Aug 2011
    North West Tas
    56 Post(s)
    Quote Originally Posted by twase View Post
    If you want the patrol image, keep a patrol motor in it!
    tappin it
  9. #28
    North brissy
    I have seen a patrol with one of those big tunnel ram bonnet scoops on it i didnt really like it but each to their own.
  10. #29
    Benarkin QLD
    tappin it
    Nah dont !!!!
    I wanna see a GQ that smokes the rear bags at 100Ks !!!
  11. #30
    Campbelltown NSW
    I can't think of any good reason at present to keep the TB42, I have spent so much time and money trying to get it to idle and not miss I will be glad to see the flywheel end of it leaving on a trailer.
