Results 1 to 9 of 9
Thread: GQ servicing
    Beginner Dave.79's Avatar
    Busselton. wa
    GQ servicing
    G'day all, I got a gq td42 its done 265k, havent had it too long..wanting to give it a major service what things should i be lookin at doin? pump and injectors have been done. any feedback appreciated.
    Feb 2011
    Shed
    45 Post(s)
    All oils and filters Engine, transfer case, gear box front and rear diffs, get your self an oil pump either manual or air if you have a compressor, these babys take heaps of oil. Make sure you can undo the filler plugs before ya drain your oils is a good tip
    RIP - valued member and true gentleman of this forum that will be missed by many! Silver's Avatar
    Feb 2011
    Brisvegas
    g'day Dave, can I suggest you get a glass of something suitable, and then take a look at this thread from general mechanical section of this forum
    http://www.nissanpatrol.com.au/forum...ve-Maintenance
    "As a boat owner and a four wheel drive owner I feel like a pelican: every where I look I see a big bill in front of me”
  5. The Following User Says Thank You to Silver For This Useful Post:
    Dave.79 (19th April 2012)
    North brissy
    All filters and oils, power steering oil, brake fluid, belts, check all bushes, wheel bearings (inspect/adjust/replace). Cooling system flush and new coolant(I would remove radiator and give it a good clean too). Valve set. Check all your mounts engine, gearbox etc. Check driveshaft unis. There is prob some i have missed hopefully others will fill in the blanks.
    Expert HammerBuilder's Avatar
    Lismore, NSW
    Like growlers said & jack it up n check front wheel bearings for too much play or leaking hubs seals n also while your going check your brake pads
    then you'll cruise trouble free for a while
    Got the baby GQ a 1997 2.8TD RX Wagon Racetech EGT & Boost Guages Dobinsons coils 32in BFG KM2 M/T
    Busselton. wa
    cheers all, 4got to mention ive done all oils, set valves ,replaced radiator and hoses +flush , repacked bearings thats about it..
  9. #7
    Busselton. wa
    yhanks 4 the link silver very interesting mate.
  10. #8
    Feb 2011
    Brisvegas
    Quote Originally Posted by Dave.79 View Post
    Yep, I reckon it's a masterpiece Dave, and a credit to the knowledge and attitudes of those who contributed (I'm not one of them :-) )
  11. #9
    Busselton. wa
    Too Rite mate!
