18th April 2012, 09:17 AM
The 747
Exide vs. Century
My battery has carked it, won't hold a charge so I'm looking to buy a new heavy duty one. There is the Exide N70EX for $215 with 620CCA from Kmart and the Century N70ZZL4WD for $225 with 760CCA from Supercheap.
I want to be able to start the car obviously, and run a stereo for a few hours with an LED on the back and eventually a winch. Which do you think is the best option here? Both have 2 year warranties.
Cheers, Chris.
18th April 2012 09:17 AM
18th April 2012, 09:33 AM
The Mad Ozzy
other option is look at the Century marine battery N70 size as it is 720cca with a 100ah rating hybrid battery, crank and deep cycle. Supercheap have them for $220ish as well so it gives you another option, they are not sealed though. If you want a sealed 1 around the same price, may pay to look at Supercharge or similar named brand
www.swat4x4.com
18th April 2012, 09:56 AM
The 747
Hmm that marine battery sounds very good, will look into that too. Cheers.
18th April 2012, 10:30 AM
They sound a bit steep go to all purposes batteries online I got a sealed marine batt delivered for like 250$ don't have site address at the moment but wouldnt b hard to find
18th April 2012, 10:38 AM
The 747
Do the marine batteries have any problems with vibrations?
Site looks good mate but unfortunately I need a new battery today!
18th April 2012, 01:20 PM
The 747
I got the 720CCA Century marine battery from Supercheap. $219
18th April 2012, 01:52 PM
Patrol Guru
KRISTOFFA
is it sealed and all that jazz whats the AH rating?
18th April 2012, 02:00 PM
The 747
Yes it's sealed, 100AH rating. So you can run 1200W for an hour before it goes flat.
18th April 2012, 04:01 PM
I have a Century marine second battery. As far as vibrations go, these batteries are designed for use at sea, choppy bumpy conditions.
Jock
18th April 2012, 04:17 PM
KRISTOFFA
The Amp Hour rating quoted is usually the 20 hour rate: you can get 5A for 20 hours.
The discharge rate for one hour will be considerably less.
The Following User Says Thank You to GeeCee For This Useful Post:
