Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: gq brake upgrade????
    now on an upgrade what brakes can i run with what size wheels ??/
    will ti twin piston go with 15 inch same with some gu i have seen with 15 inch wheels??
    cheers brett
    Feb 2012
    I have twin pistons on my gq running 15" rims and dont have any dramas
    brakes
    what rotor and caliper do you have ? gq twin piston??
    Quote Originally Posted by 4WNUT View Post
    North brissy
    Not much in the likes of upgrades unless you swap front diff out to a GU which gains more than just better brakes (larger cv's etc) A good thorough service of the brake system making sure all calipers,slides,seals and fluid are all up to spec. As for upgrading if you go to twin piston calipers you will have to change the rotors to suit as well as there are a few different thickness in the rotors and they should fit in 15" wheels. If you wanna go all out there is a company in WA which does a substantial upgrade to the front utilising gtr gear but you need to run atleast 16" rims i think.
    Feb 2012
    Quote Originally Posted by mav345 View Post
    Yep later model gq twin piston calipers, rotors and bolts
    Hardcore
    central coast nsw
    I can confirm gtr rims are alloy.
    16 inch.
    and very little clearance between cal and rim.
    you may possibly get away with 15" steel rims but you would be pushing the envelope.
    calipers are 4 pot alloy block.
    nissan rotor 296mm x 32mm
    brembo rotor 312 and up from memory.
    even larger available also, but some dont use all disc surface "smaller pads" than disc capable of handling so worth asking supplier questions first.
    and don't forget engineering is needed.
  8. #7
    does any one know what year the twin piston came out on the GQ? and how would I know if mine are twins or singles?................. sorry not very mechanically minded!!!!!
    edit: is it only the GQ EFi that has twin piston brakes? I gather thats only on the front as well? So singles on the rear?
    Looking at replacing the rotors as they may be warped, getting a bit of steering wheel shimmy under braking at any speed.
    Brembo I've heard of and had on me old Golf GTi, does anyone have any experience with RDA? or any others for that matter?
  9. #8
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Quote Originally Posted by clunk71 View Post
    Link for you clunk, sorry I have no exp with RDA
    http://brakewarehouse.com.au/catalog...v9b4rhqd594504
  10. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
    Clunk (5th May 2012)
  11. #9
    cheers mate, also seen em on ebay too
  12. #10
    Expert gec's Avatar
    Geraldton WA
    Gday Clunk, I have RDA rotors on my Patrol and they are fine, although I do prefer DBA, I found the RDA pads to be crap so I use Bendix, next time I may try those Green pads if they are not too expensive,as I have heard good things about them.
    Western Patrol Club member
    GQ with 5.7 Gen 111 V8, Dual ARB airlockers, 33" Coopers, 9000lb Premier winch, Black Widow draws
