Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Urgent Info required!!
    Feb 2012
    "So the locker can essentially float on the axles in the centre?"
    Yeah, you got it, that would be the result if it got any worse.
    Feb 2012
    Yes that i believe is correct and the install pictures show that as well. You have yours stripped and you have removed the standard gears with the splines in yes?
    Yep. In a million pieces and not looking good.
  4. #13
    North brissy
    Sounds like she been like that for a while to do that. Just to be sure take a few measurements to compare with the others before you purchase just to be on the safe side. Other than that i hope it all works out for you.
  5. #14
    Feb 2012
    Cheers Mate,
    Appreciate the help.
  6. #15
    Feb 2012
    I have found a 3 litre GU centre on gumtree....
    Can anyone tell me if they are the same centers as the 4.2 models??????
  7. #16
    North brissy
    As far as i know they are you can bolt centres out of GQs into GUs and vice versa the only thing that changes is the ratio.
  8. #17
    Feb 2012
    edit,
    Found one this evening, just whacked the lokka into the center, will install tomorrow.
    Thanks all who helped.
