Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: mk sd 33 and 5 speed into mq sd33 4 speed shorty will it all fit?
  1. #21
    oil pres and temp senders too.... im just going to use everything that comes off the mq on the new motor...oh and revers light sitch too id wager (:
    Advanced sickshorty's Avatar
    Oct 2013
    Quote Originally Posted by the ferret View Post
    5 spd into a 4 speed shorty, you will need to shorten the rear shaft, lengthen the front shaft.
    5 speed onto sd33na has a different spiggot size unless you swap the input shaft.
    You can make a spiggot bush to fit the flywheel, the sd33T and SD33NA have two sizes crankshaft bore for the spiggot bush.
    Cheers, the ferret.
    Does the same thing apply to the 5 speed from the na to the "turbo box" if there is such a thing?
