Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: 'nother neophyte (newbie) question, 17" versus 16"
    North brissy
    I run 15" rims with 35's and dont usually drop pressures any lower than 20 psi and it works good. Tyres with a larger sidewall will make a larger footprint at lower pressures. Any pressure drop on any size wheel/tyre combo is gonna net gains. But this is about rim size :P. 15 and 16" tyres are probably the easiest size to get a hold of in most situations and are still cheaper than the larger wheel size its also easier to find a load rated tyre in the smaller size as they have been around longer.
    22 Post(s)
    20?? I drop to 15 most of the time and 12 the rest
    96 GQ coil/Cab
    08 G6eT
  4. #13
    Feb 2011
    Shed
    45 Post(s)
    Have you got bead locks Ben? i usually drop to 18
  5. #14
    22 Post(s)
    Quote Originally Posted by growlers71gq View Post
    no mate Maxxis Trepadores the beads are good for 12 psi. dont know why more people dont run them
    96 GQ coil/Cab
    08 G6eT
  6. #15
    Aug 2011
    Oakland OREGON, but in Aus on holiday
    So the 17" OEM rims were for highway work ?? 80/20 rule..
    There is a lot of selection at 16" but I'll be doing mostly road driving this next year or so.
    Scott
    2004 4.2TD ST, Berrima Diesel Injector Tuned, Viper 3" SS exhaust, Cross Country Ultimate Intercooler, Solvaris sound proofing, DigOptions GPS/MMU, 220mm Roo Lights, PIONEER TS-D1602R 6.5" x 4 speakers, Autocar EGT&Boost gauges, Brown Davis 80L Aux, Icom 440, Alloy drawers and cargo barrier, 2" Amanda Extreme / Dobson / PolyAir lift, CSA mags with Toyo ATII tyres, Rhino Pioneer roof rack now with brackets, Performance 4x4 16g Large.
  7. #16
    North brissy
    Yeah thats just sorta what i have always run tyres still bag real well and less likely to come off the bead traction is good this all most of me and mates run in our tyres. I do remember one time a mate of mine had creepy crawlers and had to put 10psi in to get them to work well.
