13th April 2012, 08:10 PM
'nother neophyte (newbie) question, 17" versus 16"
Many folks have read my 'intro' but a bit of background, I had a '06 ST-L 4.8 dual fuel and kept the '04 ST 4.2 TD and now upgrading.
The ST-L rode a lot better IMHO but it had 17" OEM rims and only airbags on the rear end. I've been looking at putting on another set of tyres (tires (read-intro ) with a highway tread for the time being as there are good 16" CSA / BFG AT's on there now.
In reviewing a lot of posts, there seems to be a lot of suggestions for folks going to 16" versus 17" and there are a fair number of used 17" OEM rims/wheels for sale on various sites. I'm sure I need to consider a 2" lift when a suspension upgrade is done later in the year. I'm just scratching my head as to why the ST-L, with more K's, rode better than what I have now and the original owner said he'd not changed the shocks.
The tyre I like is a 17" (Toyo H/T) but I'm curious why there are so many suggestions to 16" ? I'm mainly concerned with highway driving right now (that will change in the future 2-3 years).
Thanks,
Scott
2004 4.2TD ST, Berrima Diesel Injector Tuned, Viper 3" SS exhaust, Cross Country Ultimate Intercooler, Solvaris sound proofing, DigOptions GPS/MMU, 220mm Roo Lights, PIONEER TS-D1602R 6.5" x 4 speakers, Autocar EGT&Boost gauges, Brown Davis 80L Aux, Icom 440, Alloy drawers and cargo barrier, 2" Amanda Extreme / Dobson / PolyAir lift, CSA mags with Toyo ATII tyres, Rhino Pioneer roof rack now with brackets, Performance 4x4 16g Large.
13th April 2012 08:10 PM
13th April 2012, 11:10 PM
Advanced
I have 17" rims on my GQ with 33" mud tyres. I have had these for around 6 years and have done 70k and are still really good in the tread.
The tyres were similarly price at the time but the rims were $140 ea vs $55 ea for 15". Cant help with any info on the 16" sorry.
I wouldn't know any reason why I would choose 16" over 17" unless there is a big price difference.
I wonder if the petrol engine has any influence on the ride between the diesel? Just a thought.
14th April 2012, 12:06 AM
I'm not 100% sure but I think in the outback a 16 inch rim is much more common and easily accessible compared to the 17, this might have something to do with it. If you're not going anywhere too remote this may not be an issue and 17s will be fine.
Is there much difference in price at all?
14th April 2012, 07:47 AM
I'm keeping the offroad tyres/rims to put back on at a later date, they are 16" CSA / BFG A/T so I've been looking at rims. 17" seem to be a problem with selection and I've looked at CSA, Speedy, ROH, All Wheels, Performance, and a few others an the ones that I'm interested in I've been told won't fit a Patrol. So if I want 17" then looking at the OEM rim (which I have no problem with except finding a set in good shape close to Jervis Bay . I was also told at the tyre shop where I get the other cars fitted out that there is less sidewall with a 17" (ya) which equates to slightly more stable ride turning and swerving to miss the potholes.
As far a pricing goes, I actually haven't asked about 16" in the same style as I want in the 17", probably should do so. You would 'assume' the diesel has a heavier front end, now if there is different suspension components would be an interesting question. I'm guessing.... nah.
14th April 2012, 09:14 AM
HuskyInAuz
Thanks,
Scott
Scott,
I have 16's on my patrol at the moment and they are LT265/75 R16 mickey thompson MTZ's on steel rims. I did this because of the trips we were doing, as it was much easier to find 16's out in the bush than 17's as not many towns stocked them at the time and would have to be ordered in. I believe now it is starting to change as more and more vehicles with the bigger tyres are heading into the outback. And the steel rims could be bashed back into shape if they got dinted whereas an alloy can't be.
Plus at the time the 17's were more expensive. I picked up my 16"tyres and rims for around the same price $400each set (tyre/rim) as just the tyre in 17's.
If you want new rims get a hold of nizzbits (he's a vendor on here) and ask him as he used to get sets of original rims and tyres in on occasion and they were practically brand new.
The tyre guy is right in that less sidewall means less roll of the tyre, but pressures and wall strength/ tyre construction would play a part as well
Greg
The Following User Says Thank You to gregs For This Useful Post:
HuskyInAuz (14th April 2012)
14th April 2012, 12:07 PM
Allied wheels mate have a good selection and range of sizes plus they can custom make there wheels to you desired offset and stud patter. I have a set on my GU they look good are load rated and she rides nice. However they are a 16" with 285/75 km2's on em. And as for the tyres 16" have a lot more range and availabilty 17" will get there as they are becoming more common now but you are more likely able to get a 16" in remote locations than a 17"
The Following User Says Thank You to nissannewby For This Useful Post:
14th April 2012, 12:40 PM
Smart like tractor
I would keep the 16's so the tyre can bag out more at low pressures.
96 GQ coil/Cab
08 G6eT
14th April 2012, 01:06 PM
Moderator
I run 16s on my GUIV as a tourer because the 16s are far easier to get in the outback, most others in a group will ahve 16s (Generally 285/75/R16) and that makes everyone able to help everyone if the worst happens on a trip.
Many guys now are going to 17s on their bush trucks running 37s but for outback the 16s are teh go.
I changed to steel rims too for the touring as they can be panel beated back into shape should you bend one rather than cracking and wrecking an Alloy. The new Alloys have a much higher load rating than a steel rim but they just not bend damn it!
16s here.
Check out my Toy -->
Rogue Dung Beetle
The Following User Says Thank You to MudRunnerTD For This Useful Post:
14th April 2012, 11:46 PM
Advanced
You dont need the tyre to bag out, they grow longer when running low. I usually go to 18 on a day out and 16 if slippery on my 17's and this makes a big difference.
15th April 2012, 02:08 PM
Smart like tractor
Rosco
2psi makes a big difference whether you're running 30 inch tyres or 52 inch tyres, I prefer the smaller rim as the surface area from it growing in length and width is greater
96 GQ coil/Cab
08 G6eT
