Results 1 to 9 of 9
Thread: What fluid for clutch?
    Apprentices Rule!!! Punderhead's Avatar
    Nov 2011
    Toowoomba, QLD
    Hi all
    Was wondering what the clutch fluid is for a 89 GQ tb42 as my lines are leaking
    Cheers!
    GO HARD OR GO HOME!!!
    My rig HERE http://www.nissanpatrol.com.au/forum...Moneypit-89-GQ
    WARNING: Towballs used in a recovery can and DO KILL people!!!
    Just some dot 4 brake fluid will be what your after mate.
    Nov 2011
    Toowoomba, QLD
    Thanks, I thought thats what it would be, just wanted a second opinion!
    Cheers!
    Aug 2011
    Most likely it will be DOT 3.
    Now we need a debate on whether you can use DOT 4 in a system that specifies DOT 3 ONLY.
    funny, i was just wondering about dot4 in a dot3 only. haven't got a clue.
    dot 4 is a better fluid i belive higher boiling temp etc same viscosity
    Aug 2011
    But a mix of DOT 3 and DOT 4 is worse than DOT 3 alone.
    Expert johno90's Avatar
    Moranbah QLD
    ^^^^ super true, mix dot 3 and 4 and it turns into sludge, if your going dot 4 then make sure you do a proper flush of the system.
  10. #9
    Nov 2011
    Toowoomba, QLD
    got some dot 3 thanks fellas
    Cheers!
