Results 11 to 20 of 24
Thread: UHF CB Radio aerial wiring
    Legendary timbar's Avatar
    Feb 2011
    perth
    Quote Originally Posted by clunk71 View Post
    Gday Leigh, I think most new antennas come with the coax already fitted as I think the base are mostly sealed units (could be wrong). Best was to do it would be to run the new cable to you uhf but you could attach a connector to your old cable and attach both cables together via the connector........ now I m no expert so not sure what having a longer run of coax would do to the reception, whether it would make it worse but i do know the more connections you have the worse the quality of reception becomes.
    Will be no more conections adrian other than th base and plug to the head unit
    tappa crappin
    1989 GQ LPG / PET TB42 LWB WAGON 4'LIFT 33's
    WELCOME TO THE MUD PITT WE DRIVE NISSAN PATROLS
    Expert Leighw85's Avatar
    Sep 2011
    Perth
    Hey Clunk
    Yeah mate i really have no idea what i can do. This is sort of the last thing i have to sort out. So trying to find the easiest way without losing quality thats for sure.
    Im in Seville Grove mate
  4. #13
    Feb 2011
    perth
    Quote Originally Posted by Leighw85 View Post
    here is what i have mate
    the wire is loose under all this
    cheers
    Yeah that base comes apart and the coaxal wire can be soldered to the brass screw conection for the arial easy job as long as the coaxal wire is long enough
    tappa crappin
  5. #14
    Quote Originally Posted by timbar View Post
    tappa crappin
    There ll be a connection if you connect the old a new cables together........ that's if Leigh decides to go fo a new base and antenna. But your right, if the existing cable is long enough he can strip the old base a resolder the cable to it, the just buy a new whip
  6. #15
    Sep 2011
    Perth
    awesome. ill pull it apart and have a look tomorrow and let you know how i go.
    Thanks mate
  7. #16
    Feb 2011
    perth
    Reread the post........i put up. .....i was simply showing an easier way to re run a NEW CABLE through the firewall then u disconect and throw away the old one.........
    tappa crappin
  8. #17
    Reread the post........i put up. .....i was simply showing an easier way to re run a NEW CABLE through the firewall then u disconect and throw away the old one......... tappa crappin
    Yeah saw that but he didn't want to have to rerun the cable to the head unit in his ov erhead consol, so I was thinking just connect new an old cables together in the engine bay
  9. #18
    Feb 2011
    perth
    Cant be done the reception breakdown would cause internal damage to the head unit the same as a uhf radio should never be used without an arial for the same reason
    tappa crappin
  10. #19
    Feb 2011
    perth
    Thanks mate
    Be sure when u pull it apart there is a small insulator near the tip of the base be sure it goes back in or u will damage the uhf radio if u need any help please pm me and i can help u out
    tappa crappin
  11. #20
    Sep 2011
    Perth
    PM sent mate
