Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: body lift for gq wagon
    ok so just had a look at the shocks and all i can see is they are red and on the bottom it says adjustable, made by koni- holland and then its got and plus and minus either side of adjustable so looks like this ( - adjustable + )
    Advanced Rosco's Avatar
    3 Post(s)
    To adjust the konis you need to remove them.
    Then there 2 little holes at the top where you push a rod through to remove the rubber bump stop.
    Then compress the shock until it stops.
    Turn the shock which ever way you want. Harder or softer.
    Pull back out to extend shock.
    Replace rubber bump stop.
    Refit and try.
    Pretty easy job. Should take about 10 min once you nut it out.
    Done mine several times before I was happy.
  4. The Following User Says Thank You to Rosco For This Useful Post:
    MudRunnerTD (30th April 2012)
