7th April 2012, 09:25 PM
Suspension Instal question
New to four wheel driving, but have had my fair share of go fast toys before.
I have just bought a 2008 GU, and am wondering how difficult it would be to instal a 2' lift kit in my driveway (driveway is cement, long, wide and flat). from what I can see all I will need is a set of spring compressors, rattle gun and a couple of hours of spinning nuts. Is it as easy as dropping out the old springs and shocks and replacing with the new ones?
Will I require a front and back wheel alignment? Will I need to get a caster/camber kit?
I was looking at the Iron man lift kit, http://www.ironman4x4.com/html/suspension_kits.html
any thoughts, tips, pointers are greatly appreciated
Biscuits
7th April 2012 09:25 PM
7th April 2012, 09:29 PM
from what you said you have enough tools, i would do a wheel alignment to be on the safe side and you shouldnt need caster correction on a 2in lift.
8th April 2012, 10:39 AM
Howdy Biscuits.
You wont even need the spring compressors mate, they will just drop out.
The only thing you will need to keep an eye on are your brake lines.
Dont forget you will need to fit a rear sway bar extension and a brake bias adjuster plate.
This is the kit I fitted to mine and as you can see it comes with all you will need to do the job right and they are good blokes too deal with.
http://www.suspensionstuff.com.au/sh...oducts_id=2879
Hope all goes well.
9th April 2012, 08:51 AM
has anyone got any pictures of what it all looks like
9th April 2012, 10:55 AM
I will do pics as I go, should get it in within the next month or so?
