Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: Indicator replacements for series 1 ARB bullbar
    Expert mick.'s Avatar
    Newcastle (NSW)
    Has anyone found someone who sells replacements for these indicators? I've seen heaps of threads about indicator replacements but not for these bars. They measure 135mm x 40mm which is smaller then most of the other bar lights.
    I've tried looking though Narva and Hella's site but I've found nothing.
    Cheers Mick.
    You may well have to go direct to ARB for replacements, as theyre probably made under lisence for them
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Mick post up an intro thread when you get a chance
    I know someone that works at ARB in Sydney that might be able 2 get them for me.
    But as Clunk said go 2 any ARB store and you should be able 2 get them
    Todd
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    You can also get LED replacement lights.
    They are more expensive but you won't have to worry about corrosion.
  6. #5
    Advanced
    Aug 2011
    Search for LED Autolamps 135AM
  7. #6
    Newcastle (NSW)
    Thanks guys I ended up getting some links from the patrol forum for the ones I was after. There a bit of an odd size and I wanted led if I could. Here's the links if anyone else ever needs them.
    http://www.ebay.com.au/itm/Indicator...item256da82bed
    http://www.ebay.com.au/itm/Indicator...item231aaa6858
    Cheers Mick.
  8. #7
    Newcastle (NSW)
    Todd
    No dramas Todd I'll do it now.
    Cheers Mick.
  9. #8
    Advanced
    Aug 2011
    The second link you posted are the 135AM that I mentioned.
    This is another case where eBay is not cheap, I payed $55 for a set.
  10. #9
    Newcastle (NSW)
    Your dead right and I find this with a lot of things on Ebay. Now I have the part number I'll be able to get those lights though one of our suppliers at work. I've found one place that sticks out which seems to be cheaper then most especially Anderson plugs. These guys are worth a look if your looking for 4wd accessories or electrical and they deliver pretty fast also.
    http://stores.ebay.com.au/autoelecau...id=p4340.l2563
    Cheers Mick.
  11. #10
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Does anyone know the part number for the standard replacement lights? is it 3500080, indicator kit?
    If it is, Mick I have a brand new set sitting in my shed (been there for about 10 years) you can have, just pay freight cost.
    If Mick doesn't want the standard lights I will offer them up for anyone.
