31st March 2012, 10:12 PM
winch question ??
ok i just got my first winch got a deal on an almost complete winch $0 dollars just had to buy a new rope / cable and hook , my question is why is a hook used , why are we not using rated bow shackles , i know it may be a dumb question maybe has something to do with safety? but i am new to winchs thought it was a good question
thanks
31st March 2012 10:12 PM
1st April 2012, 02:33 AM
I am he, fear me
You can use shackles if you want. Hooks are considered more versatile is all. As a point of interest, check out the rating on the hook, or the clevis pin for that matter, you'll be suprised at that as well.
The Following User Says Thank You to the evil twin For This Useful Post:
4th April 2012, 10:40 PM
A bow shackle can also be a bitch to undo if it is put to its limits as well unlike a hook
The Following User Says Thank You to spring_ridge_guy For This Useful Post:
4th April 2012, 10:59 PM
Moderator
spring_ridge_guy
This should not actually be a problem if used correctly? No disrespect intended.
When using a rated shackle you should do up the pin then undo a good 1/4 to 1/2 turn to avoid stress fusion and lockup of the pin after being loaded up in a recovery.
Check out my Toy -->
Rogue Dung Beetle
