Indeed. Apologies. Run s lower pressure in the rears and go for a drive.
No problems, was trying to understand how it works .. will try and post back
Just went for a quick trip on the highway .. it's difficult to say really if it's any different .. possibly .. a bit ... it's still there for sure but probably no worse than a gust of sidewind. Put it this way I certainly dont want to take my eyes off the road .. nor drive with one hand ..
Will be interested to see how far out it is and how much correction you need. It should feel planted.
yeah definitely not what I would call planted at all ..
Just had work done this morning after new tyres and alignment and a resulting pull to the left resulting from an un-adjustable caster error.
Went to Pedders (at Geebung in Brisbane) with the report from the tyre mob. They look at the report but will not accept the results. A lot of alignments done by tyre places are less than ideal - mostly because of the quality or calibration of their alignment equipment. Pedders actually have top-shelf equipment and theirs is calibrated weekly! And these blokes really know their stuff.
Checked everything, fitted the appropriate caster correction kit and aligned things properly. Now drives dead straight.
I would strongly suggest that you spend the cash to have the experts do a check if you are having tramming problems, rather than simply playing with tyre pressures, etc. These thing will only mask the real problem.
BTW the job cost me considerably less that your original quote.
I agree, an alignment at Pedders will be far better as it is their bread and Butter. Get the pros to do it for sure.
The suggestion of playing with the tyre pressures was purely for some experimentation over the weekend when no other avenue was available. Playing with Tyre pressure will never fix this, just mask the symptoms. Dropping the rear would give him the sensation of a caster change for the day to se how the change was.
I have driven a car with a new lift that tracked terribly. i was very concerned as it was my Dad's and i was delivering it to him. Had me worried. I pulled into a tyre place and found that 1 front tyre was 10psi lower than the rest of the car. Pump it up and transformed the car. So a Great place to start.
unfortunately there are no Pedders stores here that I am aware of (yes I have looked) .. there are the auto stores that sell Pedders parts and one that fits .. but they are not Pedders fitters .. closest we have is Opposite lock and ARB .. otherwise it's buying the parts (suggestions welcome) and getting others to fit them. I should know more tomorrow morning .. it will be interesting.
Southwest Western Australia
