Morning to all you auto techs ive got a 02 3l DI wagon and wanting to get a scan gauge to read temps ect
what would be the best one to get if any
is the DI an OBD11 or something else ?
dont you need nissan consult, not sure it will work with the ob2 port on a Di
I have 02 zd30 DI in an elgrand. Has obd2 socket but uses consult diagnostics.
I use a bluetooth scanner and a Samsung tablet running NDS1 app. Can do codes, display realtime data, and can log the values as well.
http://www.buyobd.com/index.php?main...&products_id=2
Sent from my SM-T355Y using Tapatalk
@Sir Roofy I take it you dont want to run any more gauges,
my water temp was easy as to install , by cutting
top hose and using a billet sender adaptor
Here's my ecu-talk ,,,,its tells me water temps only
@65 degrees,,,,,,,, reasonably easy to read with old eyes
